camshaft replacement in 4.0 - JeepForum.com
post #1 of 3 Old 07-01-2007, 10:25 PM Thread Starter
bigrobby
92 wrangler yj w/4.0 HO
alright guys at some point soon i'm putting a hotcam in the jeep. i'm getting a crane, one thats less aggresive and is not supposed to cause problems with the computer/fuel injection system. Basically i'm looking for tips, instructions, possible problems with the camshaft swap in the 4.0. i'll be replacing the valve springs as well as the lifters so i guess that means im pullin the head. i of course know to keep track of the cam and distributor position and timing. i do know what im doing in general, i've pulled heads on other cars, but i was wondering if there was anything "special" to the 4.0 i need to know about. or if ya got some instructions and time to write them it sure wont hurt anything. thanks!
bigrobby is offline
post #2 of 3 Old 07-02-2007, 06:06 AM
chupacabrah
chupacabrah's Avatar
this is from the FAQ, but not too detailed:
http://www.jeepforum.com/forum/showp...4&postcount=14
-Jon
'93 YJ with 1 ton SOA in progress (slowly).
chupacabrah is offline
post #3 of 3 Old 09-04-2007, 10:42 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
bump b/c i'd like to know too
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
Camshaft Bearings replacement ArmyFireFighter TJ Wrangler Technical Forum 8 09-19-2015 11:59 AM
Bad camshaft in some 04 TJs PackMan TJ Wrangler Technical Forum 4 01-22-2012 12:34 PM
Camshaft Replacement 2001 4.0L Jarvo2 TJ Wrangler Technical Forum 12 01-26-2009 11:35 AM
2.5L Camshaft? jaybird02 TJ Wrangler Technical Forum 1 03-19-2008 09:44 PM
HELP...Camshaft Position Sensor replacement Northern_wrangl YJ Wrangler Technical Forum 8 09-13-2007 04:43 PM
