Cam Thrust Pin and Spring? - JeepForum.com
post #1 of 3 Old 07-17-2008, 01:58 PM Thread Starter
Zazoos
Hey Gang,
My Haynes manual shows a picture of a thrust pin and spring placed in the end of the cam gear bolt head. However, they only talk about the thrust pin in the 6 cylinder section. Does the 4 cylinder have a thrust pin and spring? What is the purpose of the thrust pin?
Thanks,
Zazoos
Zazoos is offline
post #2 of 3 Old 07-17-2008, 02:16 PM
pat8942
pat8942's Avatar
Only the 6cyl engines have the thrust pin and it's to keep the cam from walking forward.
The 2.5 has a chain tensioner and the chain stays tight so the cam can't move forward but the 6cyl doesn't have a tensioner so if the chain gets slack in it the cam can move forward and the pin and spring keep tension on the front of the cam to avoid this.
That's about the best I can explain it.
Originally Posted by Zazoos View Post
Hey Gang,
Thanks,
Zazoos
pat8942 is offline
post #3 of 3 Old 01-21-2010, 03:40 PM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
With my 4.0, I6 242, how does one place the spring and pin and install the cover without it all falling apart?
hotelconucc93 is offline
Bad Thrust Bearing Baggot TJ Wrangler Technical Forum 1 02-08-2009 08:32 PM
thrust washer from D30 - can I use a TW from D35 instead? beertinted TJ Wrangler Technical Forum 4 06-20-2007 01:08 PM
Thrust Alignment? axxegrinder TJ Wrangler Technical Forum 1 02-17-2007 07:09 PM
Thrust Angle?? smkuczka TJ Wrangler Technical Forum 5 01-27-2007 05:12 PM
Thrust or what? brossie TJ Wrangler Technical Forum 3 10-06-2005 12:01 AM
