Calling all chevy TPI Swaps - JeepForum.com
post #1 of 7 Old 02-11-2013, 01:33 PM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
The donor camaro had a 4PPM VSS. Im now running a VSS with a 40 tooth reluctor ring. The engine will start and run fine until I try to move. Then the engine dies. I unhook the VSS and it runs all day, but I throw code 24 (VSS). What did you guys do for installing the VSS and making it work in your swaps?
Thanks!
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #2 of 7 Old 02-11-2013, 06:51 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
I used the Painless 60116 speed sensor hooked between the speedometer cable and transfer case, but I am using a 700R4.
http://static.summitracing.com/globa...f-60116_ml.jpg
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
post #3 of 7 Old 02-11-2013, 06:56 PM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Yeah the problem with that for me is I have the JB super short SYE for the 241C and it only accepts reluctor ring style vss not gear driven.
March 2017 YJOTM
87TPIYJ is offline
post #4 of 7 Old 02-11-2013, 07:11 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
I would call JB and see what they have to say. Maybe they have a different tone ring or sensor that might work.
5.7YJ is offline
post #5 of 7 Old 02-11-2013, 08:30 PM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
From talking to the guys over at the thirdgen forum I think a Dakota digital SGI-5 will be the best solution. I think this can be useful to other engine swap applications requiring VSS. Here is a pic and link.
http://www.dakotadigital.com/index.c...126/prd126.htm
March 2017 YJOTM
87TPIYJ is offline
post #6 of 7 Old 02-11-2013, 08:35 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Dakota has some pretty good stuff. Not a bad price either to cure your problem.
5.7YJ is offline
post #7 of 7 Old 02-12-2013, 04:52 AM Thread Starter
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
well im crossing my fingers that it does
March 2017 YJOTM
87TPIYJ is offline
