Calling all 4 bangers! This is THE BEST performance mod I've done!!! - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Calling all 4 bangers! This is THE BEST performance mod I've done!!!
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 09-01-2008, 02:20 PM   #16
1998zj
My best mod on the 2.5 is to double it's size. I have a 5.0 ford ready to go in sitting in the garage. Should be about a 200 HP improvement.
1998zj is offline   Reply With Quote Quick reply to this message
Unread 09-20-2008, 03:49 PM   #17
UNLIMITLESS
As far as $ spent on my 2.5 TJ this was by far the best upgrade. The biggest pain is getting the IAC housing off (security Torx). If you have a 2.5 DO IT!!!
2000 Jeep XJ Sport Lifted on 31s Freedom Edition
1997 TJ 2.5 Low Output SOLD!
1993 Wrangler 2.5 Low Output
1964 Ford Falcon Futura Convertible (Mopar under the hood. Shhh don't tell anyone)
UNLIMITLESS is offline   Reply With Quote Quick reply to this message
Unread 09-12-2011, 06:36 PM   #18
Pelech
So quick question, i'm thinking about taking the throttle body out of my friends totaled 98 XJ, will it fit in my 1999 TJ Wrangler 2.5L ??
Pelech is offline   Reply With Quote Quick reply to this message
Unread 09-12-2011, 07:13 PM   #19
UNLIMITLESS
Just swap your IAC housing and valve along with the TPS. No longer downshifting into 4th on the hill by my house.
Unread 09-12-2011, 07:17 PM   #20
Pelech
What's TPS, did you mean TBS as in throttle body spacer?
And i would like to switch everything out but everything is pretty much totaled im lucky that the throttle body is perfect. do you think it will work with just the throttle body?
Unread 09-12-2011, 07:24 PM   #21
Drix
Originally Posted by fyrdriver
According to this post on 4banger Jeeps site:
91-95 2.5 53007232 17.4 psi/hr
Replaceable with Ford DB5 yellow tops 19 psi/hr
Heres the link dont know if it will work?????
http://4bangerjp.com/forums/index.php?topic=3479.0
Ford 19lbs injectors are a common upgrade for a lot of vehicles. I put them on my 99 Dakota when I had it. You have get the extra air in or your gonna be running a bit rich.
95' YJ 4" lift 33"x12.5r15's D30/8.8 locked with 4:88's
USMC Jeep Club #6
"Why in hell can't the Army do it if the Marines can. They are the same kind of men; why can't they be like Marines."
Gen. John J. "Black Jack" Pershing, USA; 12 February 1918
Drix is offline   Reply With Quote Quick reply to this message
Unread 09-12-2011, 08:17 PM   #22
UNLIMITLESS
I'd have to pop the hood but I think I remember swapping the Throttle Position Sensor also. You have to use the 2.5 sensor.
