caliper removal - allen wrench size? - JeepForum.com
post #1 of 19 Old 12-01-2009, 01:24 PM Thread Starter
JIBTEXHNKA
1987 YJ Wrangler
I can't find the right size allen wrench to remove the two bolts that hold the brake caliper. These are the two that have the little rubber sleeves around them. the 4x4explor.com Aussie locker install write-up says to remove them with a 1/2" socket, but they're working on a TJ. The other write-up I'm looking at makes no real mention of them but that's on a '91... Haynes implies that the caliper design is different in pre-1990 models (mine is an '87).
The picture caption says "Using an Allen wrench, unscrew the two caliper mounting pins".
They seem just a TINY bit too small for a 5/16th or 8mm. 1/4 and 6mm are both much too small. Maybe a 7mm might fit? If that even exists.
How on earth do you get these off??
JIBTEXHNKA is offline
post #2 of 19 Old 12-01-2009, 01:36 PM
jbolty
jbolty's Avatar
are they maybe torx? chances are the bolts are not original, mine are currently 10mm hex bolts.
else, trial and error on the allen size.
jbolty is offline
post #3 of 19 Old 12-01-2009, 01:38 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
A T50 torx turned mine the last time I worked on them. I also know they could be 8 and 10 MM hex.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 19 Old 12-01-2009, 05:45 PM
93jeepyj
Are they 3/8? its been a while since ive had my brakes apart and its probably time again but I seem to remember buying a 3/8 allen socket for this.
93jeepyj is offline
post #5 of 19 Old 12-01-2009, 05:52 PM
nj95yj
mine are 1/2 hex heads
One lovely blue 97' with 33's and 4 pissed off hamsters under the hood
nj95yj is offline
post #6 of 19 Old 12-01-2009, 05:53 PM
xjchairkee
1991 XJ Cherokee
there torxs bits not allen head bits
xjchairkee is offline
post #7 of 19 Old 12-01-2009, 06:15 PM
fireshadow
maybe they are torxs on a xj but on a yj they are 7mm allen head, I just went out an checked
1988 Jeep Wrangler, home made posi lock, team rush upgrade, motorcraft 2100 carb, warn m8000 winch, np231c front yoke, rc 2.5" lift, 1" lift shackles
Even my motorcycle has a square headlight(1984 Honda Saber)!!!
fireshadow is offline
post #8 of 19 Old 12-01-2009, 09:57 PM Thread Starter
JIBTEXHNKA
1987 YJ Wrangler
they are NOT torx bits. a 3/8ths allen would be too big.
just found this in the "similiar threads" section down below:
http://www.jeepforum.com/forum/f12/i...wrench-386657/
for some reason that's always better at finding what i want then the search, ha. 7mm it is.
post #9 of 19 Old 09-01-2012, 09:39 PM
HootyBenooty
Factory caliper bolts on 90 YJ's are 8mm, 12 point socket, not torx. You have to use a 12 point socket or wrench.
HootyBenooty is offline
post #10 of 19 Old 09-02-2012, 04:02 AM
Mark05059
zombie thread revival...
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #11 of 19 Old 09-02-2012, 01:42 PM
90DesertTanYJ
When I did my calipers they were the external style torx on mine and the PO buggered them up so bad I had to use a pipe wrench to get them off. The new calipers cam with new bolts thank god and they were 3/8 or 10mm I am not sure which. I have no idea what they came from the factory with.
90DesertTanYJ is offline
post #12 of 19 Old 09-02-2012, 04:59 PM
dancytron
This is what mine had. The craftsman "works on every kind of bolt" socket set got it off.
dancytron is online now
post #13 of 19 Old 09-28-2015, 09:10 AM
hackera40
You are the man! Your information about the size and type of socket was "spot on". Thanks!
hackera40 is offline
post #14 of 19 Old 09-28-2015, 09:51 AM
mike134
and hence the reason they never list the bolt sizes. They always change from model to model and year to year
mike134 is offline
post #15 of 19 Old 09-28-2015, 10:44 AM
befumo
For my 89 they were definitely Allen.
Edit: I misread, immediately assumed we were talking about the slide pins. Yeah they are a metric 12 point socket.
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
Information on caliper pin allen wrench jeepdrvr101 YJ Wrangler Technical Forum 6 03-11-2007 09:02 PM
What size allen wrench does the transfer case fill plug take? 61 uni TJ Wrangler Technical Forum 4 07-29-2006 10:37 PM
What size allen wrench? Loser1 TJ Wrangler Technical Forum 3 01-23-2006 03:10 PM
What size Allen wrench cjb7804 TJ Wrangler Technical Forum 3 07-21-2005 12:42 PM
transfer case allen size? ukjeeping TJ Wrangler Technical Forum 2 10-08-2003 08:23 AM
