Cagle fuel control - JeepForum.com
post #1 of 1 Old 12-05-2007, 09:24 AM Thread Starter
fmrplt
1987 YJ Wrangler
Cagle fuel control
Hi guys, well with all the rain we've been having I decided to pull out some of our old magaizines and read. I came across an article in a Four Wheeler from 1993 about the Cagle fuel control. So I started looking around the internet to see if it was still around. One was available on ebay from Australia, well I don't buy from overseas.
They say in the article that they got a 21 percent improvement in mileage. It seems very interesting with they way fuel prices are.
That being said, I was wondering if any of you carb guys ever used one of these?
'93 Wrangler - Stock 4.0, Daughters daily drive. Modified HHO
'87 Wrangler - Stock 4.2, AX-15 (swap) 2 1/2" suspension lift, daily driver.
'79 CJ-5 - 6 cyl, 2 1/2" suspension lift, mostly stock - money pit.
'68 CJ5 - Work in progress. Has V-6 engine (needs rebuild) PTO Winch still working!
fmrplt is offline
Can I use stock control arm bolts on Rubicon Express control arms? LGriffith TJ Wrangler Technical Forum 2 01-10-2010 01:11 PM
P1282 Fuel Pump Relay Control Circuit yucatanstan TJ Wrangler Technical Forum 0 08-19-2006 09:24 AM
Lower Control Arm or Control Arm Bushing? YourMomma TJ Wrangler Technical Forum 3 07-11-2006 07:20 PM
"invalid fuel control" from diagnostics. Help Please! dieseldell TJ Wrangler Technical Forum 2 09-23-2005 01:30 PM
Exhaust Manifold Help : Lost on how to remove Fuel injectors, wiring, and fuel rail. Mr. Notorious YJ Wrangler Technical Forum 9 08-10-2005 06:00 PM
