CAD related question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > CAD related question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.comTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 02-05-2015, 09:54 AM   #1
tdewit
So, I did this modification (http://www.jeepforum.com/forum/f12/t...x-4wd-2989689/), but did find that the intermediate axle shaft had quite a bit of horizontal play in, causing the sleeve to not always fully engage. Is this movement normal?
Thanks
Tony
tdewit is offline   Reply With Quote Quick reply to this message
Unread 02-05-2015, 10:06 AM   #2
ghetdjc320
How much is "quite a bit"? Mine has some play in it also but it has never been enough to not fully engage a decent length on the splines
-DJC
ghetdjc320 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2015, 10:20 AM   #3
tdewit
I'd say between 3/8 and 1/2". First I did the mod mentioned above, but found the shaft would move enough in the direction of the diff that you could hear the grinding of teeth in the CAD, just slipping as it was not fully engaged. I took the CAD cover, flipped it around, and now the collar (seems to) stay engaged. The inner shaft does not have a c-clip on the diff side.
Unread 02-05-2015, 10:58 AM   #4
CrawlingForward
CrawlingForward's Avatar
This is what mine has looked like for the last 3 years with no real issues:
http://www.youtube.com/watch?v=kemFDa4Lri0
I have a little bit of a leak, but it's not negligible.
My Other Jeep Is A Jeep - Crawlingforward's Jeep-Related Adventures
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
- North Shore Jeep Club -
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline   Reply With Quote Quick reply to this message
Unread 02-05-2015, 11:14 AM   #5
tdewit
Thank you. I did actually see this vid earlier during my research. Maybe I explained it wrong. I was referring to the left <> right movement, pushing pulling to and from the diff. The bearing is fine.
Unread 02-05-2015, 11:29 AM   #6
CrawlingForward
Ah, sorry. You did in fact say horizontal. I just didn't read well, ha ha.
Nice to see my videos get seen by more than just myself, ha ha.
Horizontal play, eh?
My first thought was that perhaps it wasn't seated correctly, but that would put too *little* clearance.
Have you confirmed that it is not engaging? Or is it possible that the grinding could be from trying to disengage?
Unread 02-05-2015, 11:00 PM   #7
bergovoy
is this the inside shaft? between the cad and the differential?
bergovoy is offline   Reply With Quote Quick reply to this message
Unread 02-06-2015, 05:12 AM   #8
tdewit
Yes, the shaft between the CAD and diff is the intermediate axle shaft. The one you showed in your youtube video.
