Cab gets very hot - JeepForum.com
post #1 of 16 Old 08-15-2013, 07:09 PM Thread Starter
CBinDC
Cab gets very hot
I've noticed recently that when I drive for a good 20 minutes or more the inside of the cab, noticeably down near the legs, gets very, uncomfortably, hot. The heater is turned off the entire time too. There has to be something wrong because I don't recall it ever getting this hot. Any ideas?
Any
CBinDC is offline
post #2 of 16 Old 08-15-2013, 07:36 PM
superj
Exhaust is heating floor?
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 16 Old 08-15-2013, 07:40 PM
czjeeper
Normal, even with carpet.
When I did the Poison Spyder louver and body lift, my interior temps went way down.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #4 of 16 Old 08-15-2013, 07:56 PM
Reno72
You say the heater is off, but could the flap be stuck open? I'd check the cables and see if things are shut properly. Yes the exhaust will warm the interior up, especially if you removed the carpet and and backing, but that is mostly in the back passenger area.
Reno72 is offline
post #5 of 16 Old 08-15-2013, 07:57 PM
AmbuGrl
AmbuGrl's Avatar
Do you still have carpet?
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #6 of 16 Old 08-15-2013, 08:10 PM Thread Starter
CBinDC
No carpet. Just a bare tub.
CBinDC is offline
post #7 of 16 Old 08-15-2013, 08:12 PM
jokerchief462
How about holes in the firewall? There great for heat and check the seal around the speedo cable on the 89 it is a bog one and if it has come loose or moved you will get some heat.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #8 of 16 Old 08-15-2013, 08:13 PM Thread Starter
CBinDC
I've owned this Jeep for several years and it has never been this bad. The carpet has been out for two. I don't recall it ever getting this hot. It's bad.
CBinDC is offline
post #9 of 16 Old 08-15-2013, 08:15 PM Thread Starter
CBinDC
That could be it. I put in an electronic speedo (auto meter) and I never filled the hole up. I just ran the wires through it and left it as is.
CBinDC is offline
post #10 of 16 Old 08-15-2013, 08:16 PM Thread Starter
CBinDC
But that is up behind the dash, not down near my legs.
CBinDC is offline
post #11 of 16 Old 08-15-2013, 08:53 PM
Que89YJ
You need to see what is hot. It can be the exhaust or the heater. Get down there and feel where it's coming from.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #12 of 16 Old 08-15-2013, 09:22 PM
SloJeeper
2008 KK Liberty
I had that feeling in mine. Turned out to be coming from the access plate under the shifters. It was like a jet stream of hot air blasting my ankles
SloJeeper is offline
post #13 of 16 Old 08-15-2013, 09:32 PM
Schaef81
Samsies. After further investigation I realized the PO must have had the plate off and never put all the screws back in
BDS - Spartan - AtoZ Fabrication - Borgeson HD - USA Standard - BFGoodrich
Schaef81 is offline
post #14 of 16 Old 08-16-2013, 07:08 AM
Kuntryboy816
Kuntryboy816's Avatar
x3 on the floor plate. The mounting screws on mine had backed out a ways and was allowing searing hot air to blow through. I was also getting a fair amount of draft from the top of the shift boot for the xfer case (I have an auto). I ran a thick bead of RTV under the edge of the floor plate and screwed it back down. Then I hung a baseball cap on the xfer shifter and haven't had any issues yet.
Although for some reason the hair around my ankles doesn't grow anymore.
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is offline
post #15 of 16 Old 08-16-2013, 07:18 AM Thread Starter
CBinDC
One of the bolts on my plate no longer stays down because the hole is stripped. So that has to be one of the culprits. I'll drill a new hole today.
CBinDC is offline
