CA fuel filler issue - JeepForum.com
post #1 of 5 Old 12-15-2011, 03:02 PM Thread Starter
j24X
Help: Does anyone know of a conversion kit to allow the use of new CA approved gasoline filler nozzles? I was told by the station operator to hold the rubber back to fill, high risk of spill or face full. Looking for a side mount filler port?
thanks
j24X is offline
post #2 of 5 Old 12-15-2011, 03:24 PM
jbolty
jbolty's Avatar
What you talking about Willis?
I moved the stock filler to the side and plenty of others have done the same or used a TJ filler with no issues. I usually have to hold the nozzle up so it does not shut off, but that seems true with all my vehicles now.
jbolty is offline
post #3 of 5 Old 12-15-2011, 05:05 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Hold the nozzle up! It's a yj, even gassing up is frustrating.
Luck Favours The Prepared
Anticanman is offline
post #4 of 5 Old 12-16-2011, 11:31 AM
timatoe
timatoe's Avatar
You can hold the rubber piece back, you can lift up on the nozzle, you can move the filler to the side, etc. Those rubber boots have been on the pumps for at least ten years so not sure where you've been on that. I moved mine and used the TJ bezel and YJ filler, then later swapped in the TJ filler.
timatoe is offline
post #5 of 5 Old 12-17-2011, 12:12 PM Thread Starter
j24X
Thanks to all, I got my answers and know the direction to proceed.
Keep up the good work
j24X is offline
'88 YJ Leaking oil out of filler cap - plus another issue... dBuster YJ Wrangler Technical Forum 18 12-11-2013 02:50 PM
Fuel filler neck issue after bl Cajun78 TJ Wrangler Technical Forum 11 01-13-2010 02:07 PM
TJ fuel filler on a YJ AO1 YJ Wrangler Technical Forum 11 09-27-2009 11:25 AM
One way of dealing with the license plate/filler issue. JeepsOLot YJ Wrangler Technical Forum 20 03-08-2009 03:50 PM
RH fuel filler on TJ SteveSawyer Wrangler General Discussion 2 06-05-2008 01:03 PM
