C. Stop Lamp possesed - JeepForum.com
post #1 of 4 Old 08-19-2012, 07:03 PM Thread Starter
WanderinMan
Hello all, first posting, new member.
My center high mount stop lamp on a '95 YJ is giving me trouble. With the lights off, it operates as normal with the brakes, but it also mimics the right blinker when on.
With the lights on, the center stop lamp is constant on, turns off when I hit the brakes, and also mimics the right blinker. I'm at a loss as to where to proceed from checking the wires and the bulbs themselves, and unfortunately the Haynes manual has been no help. I've not performed any modifications to the vehicle, however it was in a minor accident a year ago. I'm not sure as to the status of the lights after the accident, as when I test the lights out using the garage floor as a reflection, everything looked normal. Before I take it back to the auto body shop, I was hoping to try everything I could. Thanks to all!
WanderinMan is offline
post #2 of 4 Old 08-19-2012, 08:03 PM
Mark05059
check all the grounds... tail lamps ground through the body mount studs
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 4 Old 08-19-2012, 10:44 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Clean up the tailgate contacts or do as I did, yank the stupid thing off!
Luck Favours The Prepared
Anticanman is offline
post #4 of 4 Old 08-20-2012, 10:16 AM Thread Starter
WanderinMan
Will check both! Thank you!
YJ
4WD lamp always on...Vacuum signal does not stop? PMW YJ Wrangler Technical Forum 8 01-10-2011 07:10 AM
replacing the brake light (stop lamp) switch schwim YJ Wrangler Technical Forum 3 08-17-2007 09:08 AM
my possesed tranny SLINKY-YJ YJ Wrangler Technical Forum 10 11-30-2004 07:53 PM
Suggestions on where to palce Driving Lamp Kit & Fog Lamp Kit!!! blackjeep04 TJ Wrangler Technical Forum 2 05-21-2004 03:03 PM
is it possesed? I-4 YJ Wrangler Technical Forum 2 03-10-2002 09:19 PM
