A/C Removal… - JeepForum.com
post #1 of 12 Old 09-18-2006, 05:42 PM Thread Starter
AR-Guy
AR-Guy's Avatar
1987 YJ Wrangler
A/C Removal…
I want to remove my A/C as I have not use it and want to do a custom dash.
My question is (yep I did do a search and could not find what I think I need)
I have an under dash A/C unit, in a ’87 YJ and it blows cold, cold air.
Can I just vent the Freon and remove all the parts or is there a better way to do this?
Thanks ahead of time,
Buck
AR-Guy is offline
post #2 of 12 Old 09-18-2006, 06:15 PM
JTB51B
Most any small garage will collect it for the freon. Or they will as long as freon prices stay high. If not, shhhhhhhhhhh
Jason
DD-- 2005 Dodge Ram 2500 Cummins TD Quad Cab 4x4 6 speed
Toys:
1998 Sport Auto trans, 3.73 gears, D30/lockright D44/Detroit, 33" Mud tires, FT LCA's JKS Adj. Trac bar FT 4" coils, RE GEN II Disco's--1 1/4 JKS BL, 1" MML XD9000i up front, HD bumpers with extraction points.-Done.
1973 cz 250 MX Not much suspension, but 36 BHP at 6k rpms!
2006 Rhino SE, 27" Mud lites and a cupholder.
JTB51B is offline
post #3 of 12 Old 09-18-2006, 07:45 PM
JJorda
Jeep. Jeep? Jeep! Jeep.
JJorda's Avatar
Yeah, shops'll do it, you may have to look a little bit to find a place that'll reclaim R-12, but I'd have to say most places would have the proper equipment.
Also - is your system for a 4.2 with V-belts, factory air? Would you be interested in selling the parts once your system is removed? PM me if you're interested....
1989 Jeep Wrangler - Daily Driver and project - Red Jeep Club #216, NRA Jeep Club #5
1967 Chevelle SS396 - Main Project <--454, TH400, 4.10's, FAST
1982 Caprice Classic - Another project <-- 350/700R4, 4 wheel discs
1979 Honda Civic CVCC - Yet another project <--goal of 60 mpg
JJorda is offline
post #4 of 12 Old 09-18-2006, 07:59 PM Thread Starter
AR-Guy
AR-Guy's Avatar
1987 YJ Wrangler
Originally Posted by JJorda
Also - is your system for a 4.2 with V-belts, factory air? ....
JJorda,
Yes it is a 4.2 and I do believe it was/is factory. I do not know if it is V-belts or not-I have two belts and could post pic’s if needed.
Everyone,
After reclaiming the R-12 any tips on removal of the rest of the stuff?? Plugging the firewall?? New belt configuration??
Thanks again.....
Buck
AR-Guy is offline
post #5 of 12 Old 09-18-2006, 09:02 PM
YJ Newby
2nd dibs after JJorda if you intend to sell and he decides against it. I need 4.2 with serpantine, but will gladly swap out pulleys to stifle the Arizona summers if the price is right. Let me know via PM. . . .
Thanks
YJ Newby is offline
post #6 of 12 Old 11-02-2010, 09:23 PM
jth0033
1987 YJ Wrangler
i know this thread is incredibly old but i was wondering if anything came about with your removal. i've been trying to do research on this and haven't found anything good. how did you route the belt? delete pulley? shorter belt?
jth0033 is offline
post #7 of 12 Old 11-02-2010, 09:43 PM
jbolty
jbolty's Avatar
I took mine out and replaced the compressor with a york, for on board air. Lucky to find a 4.2 AMC pacer in the junkyard with a york 210R and the bracket.
jbolty is offline
post #8 of 12 Old 11-02-2010, 10:00 PM
jth0033
1987 YJ Wrangler
i have been reading into the a/c to oba conversion and i think that might be the way to go. thinking i might just use the factory compressor and go from there
jth0033 is offline
post #9 of 12 Old 11-03-2010, 06:29 AM
five-string
That's interesting. I didn't know you could have OBA from the factory A/C compressor. I am going to remove my factory air also but if I can turn that compressor into a cheap oba then I am all for it.
Boycott shampoo! Demand the REAL poo!
White Jeep Club #119
☼lllllll☼
five-string is offline
post #10 of 12 Old 11-03-2010, 06:54 AM
jth0033
1987 YJ Wrangler
yea due a search there are a few write-ups. i can post one here for you to check out too
http://www.jeepforum.com/forum/f11/c...p-pics-471962/
read a few pages, he eventually makes a list of stuff you need and changes the one hose
jth0033 is offline
post #11 of 12 Old 11-03-2010, 07:11 AM
Dre40
hay if you want to sell the parts you are removing let me know..
Dre40 is offline
post #12 of 12 Old 11-03-2010, 07:55 AM
five-string
Dre40, pm sent
☼lllllll☼
Air Dam Removal liquidean JK Wrangler Technical Forum 8 09-11-2009 03:12 PM
Oil Pan Removal Help TjBryce TJ Wrangler Technical Forum 3 09-06-2009 04:21 PM
CPS removal seattlejeepster YJ Wrangler Technical Forum 0 03-01-2008 05:04 PM
HT Removal Sidewalkman YJ Wrangler Technical Forum 4 07-12-2003 07:14 PM
hub nut removal black pete YJ Wrangler Technical Forum 5 07-10-2003 07:03 AM
