A/C and drive belts - JeepForum.com
post #1 of 3 Old 04-27-2001, 01:59 AM Thread Starter
donnyg
2014 WK
A/C and drive belts
I have an '87 YJ, 258 I6, which I beleive has a V belt. There are what seems to be two narrow belts. One spins off the alternator, the other spins on something connected to the fan. Does this sound like a V belt? I know someone that has an '87 YJ Sahara with a serpentine belt and A/C and he is parting out his Jeep.If If I have a V Belt and he has a serpentine how hard would it be to swap his A/C setup into my engine? What else would I need? Is it possible for two '87 258's to have to different belt set ups like that? Any help would be greatly appreciated. Thanks.
Donny
donnyg is offline
post #2 of 3 Old 04-27-2001, 09:18 AM
jeeptuff
The conversion to a serpentine is not difficult just teedious and time consuming.
All the pulleys have to be changed and in one case I saw an altornator that had to be shimmed for proper alignment. If you go serpentine remember to carry a spare belt with you. And BTW there are idler pullies that have to be installed that is the ****tiest part of the whole conversion.
Eric
Once again Jeepless in Seattle
jeeptuff is offline
post #3 of 3 Old 04-27-2001, 12:52 PM
osburn
osburn's Avatar
You might be able to just swap the pulley on the air compressor to v-belt and if you don't have an empty groove to drive the compressor swap the pulley on the alternator or something. Contact Brad Kilby at http://www.onboardair.com He's the guru of onboard air and belts and pulleys and stuff. I know he even has custom pulleys made for some Jeep applications.
Matt Osburn
Score 1032
osburn is offline
Fan Belts Yonni YJ Wrangler Technical Forum 8 12-14-2009 08:47 AM
oba and alt belts JRD917 YJ Wrangler Technical Forum 3 07-31-2008 07:42 AM
For those of you with V belts and AC pyro9862 YJ Wrangler Technical Forum 1 10-11-2005 06:05 PM
Help!!! Belts Won't Go On cheesycook TJ Wrangler Technical Forum 13 04-15-2005 11:45 AM
belts 2 or 3??? trYJ YJ Wrangler Technical Forum 3 02-02-2003 09:20 AM
