c clip removal - JeepForum.com
post #1 of 3 Old 07-07-2009, 03:27 PM Thread Starter
amajeeptour
c clip removal
What is the best way to remove a c clip off of a dana 30 axle?
amajeeptour is offline
post #2 of 3 Old 07-07-2009, 03:36 PM
Goobersbro
well first you will have to check to see if you dana 30 has a c clip some do some don't. then all you have to do is just push the shaft in a little and remove the c clip with some needle nose or whatever and then your good to go
Goobersbro is offline
post #3 of 3 Old 07-07-2009, 08:54 PM
dbikers
^X2...exactly what goober says
STUPID HURTS.......OUCH!@#$
dbikers is offline
AX-5 5th gear clip & collar repair without trans removal Mean Max YJ Wrangler Technical Forum 142 07-18-2016 03:43 PM
Clutch Pedal Clip Removal pointblanke TJ Wrangler Technical Forum 7 08-25-2011 09:44 PM
U Joint retainer clip removal help YJames90 YJ Wrangler Technical Forum 3 07-27-2009 08:04 PM
Front clip removal jeepwrnglr92 YJ Wrangler Technical Forum 7 11-21-2007 01:23 PM
Dana 35 C-clip Axle removal Paulwpetrea YJ Wrangler Technical Forum 2 08-21-2002 11:54 AM
