Has anyone had any experience with the c-clip eliminator in a Ford 8.8 rear axle?
I am trying not to weaken the gears in my 8.8 build by grinding teeth to put the cross pin in. I read a thread where they grind the cross pin, not sure what the right approach is.
The idea of being able to replace a broken axle without pulling the aussie locker apart has some appeal.
The 4:56 thick gears are making the build more difficult than I envisioned when I started. I'm so close to being able to close up the diff cover I can taste it. :smile2:
Don't worry about grinding the tip of one ring tooth. Do it easy to not heat it too much. I finessed it down with a flap wheel.
I later did the c-clip elim, but only for track reasons. I have Warn hub kit in front, which widens the track 2". The stock 8.8 is 1/2" narrower than a D35, so I initially used 1.25" spacers in the back to even the Jeep out. The c-clip elim installed later widened the back 2" too, and of course also eliminated the c-clip.
Like Don said, don't worry too much about making room for the crosspin. You're not gonna shred your ring gear because you had to clearance a tooth or 2. Your contact area should be below that anyway.
On the other hand the Yukon Ultimate 88 kit offers several advantages. Like Don, I mainly installed it for track width/clearance reasons.
I put in a Super 88 kit. From the now defunked Superior Axle. Which was axles and c-clip eliminators as a set.
I did it for the cro-mo axle shafts. But it does add 1 inch width to each side (the 8.8 was 1/2 inch narrower each side than the d35 was, so it recovers that and adds another 1/2 inch)and adds overbuilt bearings. C-clips are really not a breakage point for the 8.8.
BUT.. For me, I can not go backwards. If something does happen, I can not use stock 8.8 axle shafts, and the housing has been cut and grinded on. And Superior is out of business.
Mediceagle, go ahead and grind a tooth, it's fine, as we (I? lol) seem to be hijacking this thread, sorry.
Jeepster, I have the old Superior kit too. If I recall, the axles are regular Ford 9", just the correct length we need. I just looked to see Summit racing has the 31 spline Ford 9" axles in a LOT of different lengths. It would be nice to be able to figure out what our axle shaft lengths are from Superior so we'd know what to buy if needed.
I am very interested the turn of topic. I had thought of changing to a c-clip eliminator out of pure cowardice. But the expense without immediate gain is not smart. After I break something then I may change my mind.
I have so much time just making the, AMC Jeep made in Canada on Friday the week before they sold out to Chrysler, be reliable that I get overly cautious.
If you're doing a c-clip eliminator to remove a big weak spot...C-clips really aren't the biggest issue.
The "weak" spot in an 8.8 is...from what I understand...is a bendable axle flange. And the tubes.
Weld your tubes.
Watch the side hills.
I bent my axle at the flange somehow and that was the start of my super 88 road.
I'd bet at least $2 that Yukon bought that product from Superior, of not the whole company. I just tried to call Yukon, was busy, so I sent an email asking if their kit is the same as the old Superior kit. I'll post back if I get an answer.
I watched one of my dear friends design & build the very first one (prototype) for Superior. He had me chip in a little to see if even a sloppy fabricator like myself could follow simple directions as he gave me instructions for one side.
The rest is history from there. I got the second kit ever made & I installed it mostly by myself as the instructions were being developed. My YJ was the Jeep used in the 4 Wheeler magazine article.
My need to upgrade from stock 8.8 parts was due to repeatedly bending 8.8 shafts AND the axles were bottoming out against my ARB cross pin & bending the cross pin of the ARB due to serious side loads.
I got one of the last Superior kits ever built! On ebay at a crazy price! Well, may be one of the last but it's sitting in my garage waiting to be installed. Came with stickers and everything!
Side loads can kill 'em. I bent at least one in Moab, at least one in Colorado, and a few in Johnson Valley/Hammers trails. Splines were twisted on one.
I carried spares - so no big deal. Even when I swapped to the Super 88 kit, I carried assembled spares for each side.
The Super 88 served me well & I have no complaints. I no longer run the Super 88.
My drivers side flange was bent on my 8.8. Perhaps I got it like that as it came from a wrecked exploder. The tire wobbled a bit. Could not feel it but could see it wobble.
That is why I upgraded.
So...breakage...
I sort of remember that Superior had a small batch of axles that were heat treated improperly and broke. All those were removed and replaced. Mine was not one of those. Anticanman had one break.
The c-clip eliminator put a bigger bearing in a better place with a stronger flange...flange bending issue delt with.
Add another to the list of no more c-clips. I have the yukon super 8.8 kit and I am very happy with it. The install was really straight forward. Hardest part was pressing on the bearings. (had to use the shop press where I work, as mine is too small)
I like the added width and the dual bolt pattern flanges. I have swapped to 5 on 5.5 in pattern because of a front hub conversion, so the width and bolt pattern of the kit worked perfect for me.
One more reason to carry lots and lots and lots of zip ties.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
