Bye Bye Rhino... - JeepForum.com
post #1 of 11 Old 12-05-2012, 07:24 PM Thread Starter
Chrisnvegas
Chrisnvegas's Avatar
Bye Bye Rhino...
The Jeep (92 Sahara 4.0 auto mostly stock, 99,000 mi, mint) has been sitting in the garage for a couple of years. Took it out occasionally, but not really off road.
I used the Yamaha Rhino for that. Well, I'm done. Too slow and unstable.
Now I have some mods to do. I have been reading this forum for a while.
Hope you guys know what you just started!
Chrisnvegas is offline
post #2 of 11 Old 12-05-2012, 07:42 PM
sdotcarter
Pics!
First things first.
1. Full tune up: plugs, wires, oil, plugs, transmission/tcase/different fluid, flush radiator, check break fluid, check vacuum lines and Rad hoses for cracks.
2. Remove front and rear track bars, then grease your ball joints drive shafts and tie rods.
3. Hang a air Freshener.
4. Enjoy that Jeep!
sdotcarter is offline
post #3 of 11 Old 12-05-2012, 08:05 PM
RDRosie
I've seen conflicting comments on track bars -- I use my Jeep to transport hockey gear quite a bit (instead of the sports car) and am concerned with on-road safety with the bars removed. Some say it is best without them and others claim it is unsafe...
RDRosie is offline
post #4 of 11 Old 12-05-2012, 08:16 PM
Rproject
1987 YJ Wrangler
Here we go again.
Track bars - put them in the trash
Sway bar - if you think it's unstable with a load on the vehicle, leave it on for on road. Disconnect it for off road performance.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #5 of 11 Old 12-05-2012, 08:19 PM
bill8bud
Adding track bars was a way to keep Jeep safe from lawsuits from lawyers. I run no track bars or sway bars on my Jeep and I love it. Do maintence listed above and plan on what you want your Jeep to be so you can plan your build correctly.
Enjoy your new habit.
bill8bud is offline
post #6 of 11 Old 12-05-2012, 08:23 PM
CrawlingForward
Yup, start slow with mods for sure.
Track bar removal helps a ton with the ride. I prefer my sway-bars connected on-road, but definitely need a disconnect for off-road.
Good easy (relatively cheap) things to start upgrading are diff covers, swaybar disconnects, skid plates, automatic lockers, and other things that help a *ton* when you're stock, but don't become obsolete once you decide to lift and add bigger tires!
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #7 of 11 Old 12-05-2012, 09:03 PM
CleverNameHere
Originally Posted by Rproject View Post
Here we go again.
Wait!! Don't toss em!! I'm gunna use mine to build a swing away tire carrier since they already have the bushings. Maybe you have another plan for one?? or just don't want to deal with it and throw em away, Your choice
CleverNameHere is offline
post #8 of 11 Old 12-05-2012, 10:00 PM
bill8bud
Track bars are also good to keep around to stoke a fire...
bill8bud is offline
post #9 of 11 Old 12-05-2012, 10:23 PM
Xpress
Or use as persuaders.
All about that unibody life.
Xpress is offline
post #10 of 11 Old 12-05-2012, 11:15 PM
CleverNameHere
^ Those options are good too... A bit psychotic, but good. Now, back to topic. Where are those pics Chris??
post #11 of 11 Old 12-05-2012, 11:35 PM
Bl4cK_kNiF3
I always use mine as a cheater bar to break bolts loose! works awesome!
1995 Jeep Wrangler YJ, AMC 242, AX-15, 4" Rough Country Lift Kit, Hunter Green
Green Jeep Club Member #360
Bl4cK_kNiF3 is offline
