Buying a YJ - JeepForum.com
post #1 of 9 Old 04-01-2010, 08:48 AM Thread Starter
Leoboy297
1987 YJ Wrangler
Buying a YJ
I am going to look at a YJ this weekend, and i have been talking to the guy a lot it seems pretty decent its a 1990 4cyl 5 speed 140K, and my question for you guys is, when i asked him about the 4x4 he said exactly "it works, but sometimes it doesnt want to disengage because it's vaccuum opperated". I know that's true, but is he trying to cover something up ? What can i do to test it? I'm new to YJ's. Thanks Guys
A.M.C.
Leoboy297 is offline
post #2 of 9 Old 04-01-2010, 08:52 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
If your in lower central upstate, I will take a look at it for you.
The fork might be sticking. just sounds like a negotiating point to me , known issues =worth less. a lot of people just bypass the vacuum dico anyway. I don't consider that a big issue.
edit- on second thought.... maybe it doesn't disengage because the jeep isn't done wheeling yet. buy it and listen too it, it will tell you when it's time to leave the trails
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #3 of 9 Old 04-01-2010, 08:52 AM
Allen52105
eather way I would pass on the jeep....just for the fact its carb. that is unless its a GREAT deal. got a pic and info on it?
jason
Allen52105 is offline
post #4 of 9 Old 04-01-2010, 09:01 AM Thread Starter
Leoboy297
1987 YJ Wrangler
The Jeep is in good condition besides the drivers side floor, it has a new clutch, new radiator, and new tires.. I dont know i mean i am probally going to look at it.. i just dont know what to do.
post #5 of 9 Old 04-01-2010, 09:02 AM
autoboy454
it's a 4cyl, so no carb. I don't think Jeep made a carbed 4 cylinder (in the YJ's, let's not get into F-heads )
I would also like to get a couple pics of it if you snap some when you go to look at it again. My brother got his YJ for pretty cheap because the Vacuum Disco wasn't functioning right too (and there happened to be a lot of rust... )
Love to wheel? Live in/around Massachusetts? Check us out!
autoboy454 is offline
post #6 of 9 Old 04-01-2010, 06:18 PM Thread Starter
Leoboy297
1987 YJ Wrangler
Anything else you guys would suggest looking for overall when i go to test drive and look at this thing? any input helps. thanks!
post #7 of 9 Old 04-01-2010, 06:24 PM
I8AHUMR
Tap the frame at various points with a screwdriver and make sure there's no frame rot if you think it's been neglected at all. Pay attention around the area in front of the rear crossmember. Around the rear shackle. Also around the power steering up front.
If the vacuum disco is intermittent its probably not that big of a deal. You could go to a posi-lok for about $200 or go the homemade posi-lok route for $50-$75. Not a deal breaker IMHO...
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #8 of 9 Old 04-02-2010, 09:36 PM Thread Starter
Leoboy297
1987 YJ Wrangler
Anything else anybody could give me some tips on before i go look at it tommorow ?
post #9 of 9 Old 04-03-2010, 02:41 AM
Dhofstet
1973 KK Liberty
Ask yourself if you really want a 4 cylinder. Is this going to be your DD? I wish i got a 6 but at the same time i am happy i do have a jeep. Only reason i bought the 4 is because i was desperate for a jeep and it was a good deal.
As mentioned, check for frame rot, rust, test out the 4x4. How much is he asking?
Spineless, and mindless, You flex your muscles but not your F***ing head..
Dhofstet is offline
Buying a yj yjasoldasiam YJ Wrangler Technical Forum 15 11-29-2009 04:58 PM
Buying new 09 JK stormrider JK Wrangler Technical Forum 34 02-09-2009 07:24 AM
TJ What to look for when buying hickory TJ Wrangler Technical Forum 19 08-15-2008 06:35 PM
Buying Springs vs. buying a "lift kit" DILYSI Dave YJ Wrangler Technical Forum 17 06-27-2007 06:15 AM
If you were buying new BigCanoe TJ Wrangler Technical Forum 20 02-18-2004 08:56 AM
