Buying used gears? - JeepForum.com
post #1 of 4 Old 05-04-2007, 08:44 AM Thread Starter
nolo263
Buying used gears?
Is it ok to buy used gears for the front diff?? I have a chance to pick some up cheap..
nolo263 is offline
post #2 of 4 Old 05-04-2007, 08:51 AM
93YJfalcon
I've been using my $25 d-30 gears since last summer. As long as they look OK and you set them up right, I don't see why not.
ROCK OVER LONDON... ROCK ON CHICAGO!
93YJfalcon is offline
post #3 of 4 Old 05-04-2007, 08:53 AM Thread Starter
nolo263
thanks brother I will go ahead and buy them.
nolo263 is offline
post #4 of 4 Old 05-04-2007, 09:48 AM
Tulsachokehold
Make sure there are absolutely NO chips in any of the teeth on either the ring gear or the pinion. if they have chips... don't buy them.
'91 YJ. 4.0 TF999, D300 w/ 4:1, twin sticks. Chevy D44 front, 4.10's, spooled, Yukon 4340 shafts w/ super joints. Warn premium lock outs, High steer, ram assist. Dodge D60HD rear, 4.10's, welded, disc brakes. SOA front w/ RE 1.5" SOA leaf packs. Custom 4 link rear w/16" fox air shocks, stretched to 110". 38x12.5x15 TSLs on crager Nomads w/ DIY beadlocks. Tolly Fab Tube fenders, rocker gaurds, cage. 15gal stainless steel fuel tank.
Tulsachokehold is offline
Buying a JK - Questions on gears and drivetrain RollinThunder85 JK Wrangler Technical Forum 3 12-11-2008 04:42 PM
Buying new rear axle w/wrong gears Cash TJ Wrangler Technical Forum 30 11-21-2007 06:16 AM
Buying gears on Monday shamby YJ Wrangler Technical Forum 6 11-18-2006 11:49 AM
Buying Speedo Gears Online Tex77 TJ Wrangler Technical Forum 10 04-17-2005 02:31 PM
Axles, gears, 31's ? Buying first used jeep Q's SMOKE Dog TJ Wrangler Technical Forum 4 03-23-2005 10:18 AM
