Buying New Shocks - JeepForum.com
post #1 of 4 Old 07-31-2011, 05:00 AM Thread Starter
DanielShearer
Buying New Shocks
So I'm buying new shocks cause I recently blew all 4 of mine out. I'll be buying them through Quadratec. Posting this because I just have a few questions.
-any specifications I need to pay attention to/find out??
-if you have bought shocks from the website or other websites any suggestions?
-special tools needed and about how long would it take to install
-differences between the front shocks and rear shocks.
Thanks for any help you can give me.
Cheers, Dan.
DanielShearer is offline
post #2 of 4 Old 07-31-2011, 03:10 PM Thread Starter
DanielShearer
bump
post #3 of 4 Old 07-31-2011, 08:38 PM
Smitty1
shock install
Length of shock is important. If you are buying from Quadratec the salesman on the fone should be very helpful in getting you the right part numbers ordered after you decide which brand shock you want.
Lots of PB Blaster and heat will make the job a breeze. Be sure to torque them down to spec.
Smitty1 is offline
post #4 of 4 Old 08-01-2011, 09:05 AM
cplayer5
Make sure to let them know if you run any lift, I just replaced mine with the Rough Country 8000's. Got all 4 plus the steering stabalizer for $140.00 shipped, they ride great. Install was a breeze, took maybe an hour. I had to reuse the sleeves in the rear shocks because the ones that came with the shocks were too small; front shocks had 2 different size sleeves. Now the steering stabalizer.... wasnt as quick and easy, but a little heat will do the trick.
cplayer5 is offline
advice , quadratec , question , shocks , tools
need help buying new shocks bigred94 YJ Wrangler Technical Forum 3 11-26-2010 07:04 PM
buying new shocks jeepoffroad18 TJ Wrangler Technical Forum 5 11-25-2010 07:25 PM
When buying shocks.... kennyboobear TJ Wrangler Technical Forum 6 11-01-2010 07:19 AM
question about buying shocks with my lift archer75 TJ Wrangler Technical Forum 10 09-27-2007 08:52 PM
New-Be need help on buying shocks and maybe springs Slithering_Joe TJ Wrangler Technical Forum 7 02-06-2006 09:40 AM
