burning oil and running rich - JeepForum.com
post #1 of 4 Old 06-10-2010, 06:56 AM Thread Starter
ton12loc
I have a 92 4.0L and sometimes while driving and when I shift gears I can see some blue smoke from the exhaust. the jeep does burn some oil also, plus it smells like it is running rich and the smells gets bad enough to give a headache but I'm used to it, wife hates it lol I know I pretty much need to do a rebuild on engine but is there a quick fix or cover up for the blue smoke but more so for the smell..that is somewhat annoying...thanks
ton12loc is offline
post #2 of 4 Old 06-10-2010, 07:51 AM
Que89YJ
If your running rich then you have either a bad temp sensor, O2 sensor, or the manifold is missing bolts/lose, or crack which is common especially near the rear by the firewall.
Que89YJ is offline
post #3 of 4 Old 06-10-2010, 07:58 AM
88blkyj
get a compresssion test and see what cylinder is bad. also do a wet and dry to test to determine why your burning oil
88blkyj is offline
post #4 of 4 Old 06-10-2010, 11:19 AM
pasinbuy
I am surprised that your plugs are not fouling out. You should check them to see which cylinder if not all, is bad. You might want to start checking on a rebuilt motor.
How many miles on it? How bad does the oil look?
pasinbuy is offline
running very RICH!!! help jptaylor2 TJ Wrangler Technical Forum 6 10-04-2007 09:11 AM
running rich bamacj YJ Wrangler Technical Forum 5 01-16-2007 01:34 PM
2.5 running rich KOTA YJ Wrangler Technical Forum 0 08-13-2006 09:11 PM
Running rich Andy1100 YJ Wrangler Technical Forum 9 12-16-2005 11:18 AM
Running rich. MAjeep87 YJ Wrangler Technical Forum 9 07-21-2003 07:40 PM
