Bumperette problems - JeepForum.com
post #1 of 10 Old 06-04-2013, 07:33 PM Thread Starter
yjlivin
Bumperette problems
Soo I have a 1992 yj and I'm trying to take the bumperettes off but I can't get to the back of the inside 2 bolts any help or suggestions???
yjlivin is offline
post #2 of 10 Old 06-04-2013, 08:28 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
A wrench...?
Luck Favours The Prepared
Anticanman is offline
post #3 of 10 Old 06-04-2013, 08:38 PM
bigbossd1030
He is right. You just need a normal wrench nothing fancy. You need patience and you just gotta work it in there. It's not really that hard.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #4 of 10 Old 06-04-2013, 09:38 PM
jokerchief462
Cutoff wheel.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #5 of 10 Old 06-04-2013, 10:39 PM Thread Starter
yjlivin
yjlivin is offline
post #6 of 10 Old 06-04-2013, 10:43 PM
Recce2895
You just need to use a cutoff wheel
Recce2895 is offline
post #7 of 10 Old 06-05-2013, 06:06 AM
StanF
A 3/8 drive 9/16" deep socket worked for me. It's a pain, but doable. Driver's side is fairly easy. The exhaust pipe makes the Passenger side more difficult. Something else that I tried and was successful with (on the passenger side)...I used a couple of long 12" extensions to move the ratchet out towards the axle. It's still tight, but it fits, and you can hold/turn the ratchet. I have a ratchet with a pivoting head, which is nice, but probably not necessary.
StanF is offline
post #8 of 10 Old 06-05-2013, 06:52 AM
Reddy89
Reddy89 is offline
post #9 of 10 Old 06-05-2013, 07:12 AM
Rproject
1987 YJ Wrangler
After copious amounts of PB Blaster to loosen the ancient bolts, you will need to fiddle with the right size socket and/or box wrench to get on them. The easiest way I've found is to work from the outside - in. The outbound bolts interfere with getting to the inbound bolts, or at least it's easier to get to the inbound bolts with the outbounds out of the way.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #10 of 10 Old 06-05-2013, 07:14 AM
UZI4U
MCLMM
UZI4U is offline
