-   -   Bumperette problems (http://www.jeepforum.com/forum/f12/bumperette-problems-1532466/)
yjlivin 06-04-2013 07:33 PM
Bumperette problems
Soo I have a 1992 yj and I'm trying to take the bumperettes off but I can't get to the back of the inside 2 bolts any help or suggestions???
Anticanman 06-04-2013 08:28 PM
A wrench...?
bigbossd1030 06-04-2013 08:38 PM
He is right. You just need a normal wrench nothing fancy. You need patience and you just gotta work it in there. It's not really that hard.
Sent from my iPhone, probably because I am bored at work.
jokerchief462 06-04-2013 09:38 PM
Cutoff wheel.
yjlivin 06-04-2013 10:39 PM
Recce2895 06-04-2013 10:43 PM
You just need to use a cutoff wheel
StanF 06-05-2013 06:06 AM
A 3/8 drive 9/16" deep socket worked for me. It's a pain, but doable. Driver's side is fairly easy. The exhaust pipe makes the Passenger side more difficult. Something else that I tried and was successful with (on the passenger side)...I used a couple of long 12" extensions to move the ratchet out towards the axle. It's still tight, but it fits, and you can hold/turn the ratchet. I have a ratchet with a pivoting head, which is nice, but probably not necessary.
Reddy89 06-05-2013 06:52 AM
http://www.jeepfan.com/reviews/PB/PBCatalystLG.gif
Rproject 06-05-2013 07:12 AM
After copious amounts of PB Blaster to loosen the ancient bolts, you will need to fiddle with the right size socket and/or box wrench to get on them. The easiest way I've found is to work from the outside - in. The outbound bolts interfere with getting to the inbound bolts, or at least it's easier to get to the inbound bolts with the outbounds out of the way.
UZI4U 06-05-2013 07:14 AM
http://www.brownells.com/userdocs/pr...71100008_3.jpg
The time now is 02:13 AM.
