bumper bolts - JeepForum.com
post #1 of 4 Old 04-03-2013, 07:03 PM Thread Starter
boatsandhose
bumper bolts
So the stock rusty tow hooks had sheared off long ago and I am in the process of putting on my metalcloak bumper. Both bolts are sheared. If I drill them out, how do I make new threads in that welded nut?
90 YJ locked f/r 37s d30 F8.8
boatsandhose is offline
post #2 of 4 Old 04-03-2013, 07:09 PM
jbolty
jbolty's Avatar
I would just knock it through and put in new nuts. You just need to tack weld it in place to hold it long enough to get the bolts started. For that matter you could glue it in.
jbolty is offline
post #3 of 4 Old 04-03-2013, 07:17 PM Thread Starter
boatsandhose
Ok yeah that makes sense now. Should I just replace the torx bolts on bottom with hex? Thanks.
post #4 of 4 Old 04-04-2013, 08:10 AM
jeff_in_rc
Yes, replace all of the bolts with hex grade 8 and you will be good.
2004 Jeep Wrangler Rubicon
Member of the Gear Grinders 4WD Club
jeff_in_rc is offline
