Bump stop Question - JeepForum.com
post #1 of 2 Old 03-16-2004, 08:51 AM Thread Starter
TaylorTN
Bump stop Question
I need to replace the rear stops on my 94. I saw the extended set (front and rear) on Quadratec for $100. I am not that interested in replacing them....
I also saw some CJ rear stops for $20 a pair. Any reason they wouldn't work, even with a little modification? Just curious. I thought I'd work on this while I have it up putting the lift in.
TM
TaylorTN is offline
post #2 of 2 Old 03-16-2004, 12:16 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
do you need new bump stops, or just extended bump stops? if you need extended... just shim them. for new ones... well, just go for it.
price is high, so.. i'd shop around.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
bump stop question bsmitty45 TJ Wrangler Technical Forum 2 11-10-2008 08:39 PM
bump stop question Winters TJ Wrangler Technical Forum 4 03-21-2008 09:58 AM
Bump Stop Question Toombs TJ Wrangler Technical Forum 6 03-14-2006 08:31 AM
Bump Stop Question ctcjason TJ Wrangler Technical Forum 8 03-10-2005 10:07 AM
BUMP STOP QUESTION tstrong12 YJ Wrangler Technical Forum 8 04-24-2003 11:07 PM
