Bump stop extension? - JeepForum.com
post #1 of 7 Old 11-05-2011, 12:15 PM Thread Starter
BIGJoe29
hey i have a stock 1990 yj and i'm getting a trailmaster 3 inch lift(no shocks) with bilstein 5100's, i read somewhere that i will need to buy new bump stops. i dont know wat i need or even wat to do with them. any advice or recommendations will b great. thnx
2.5L w/ AX-5, NP231J w/ Rugged Ridge SYE and XJ front driveshaft, open D30 and D35 w/ 4.10 ratio, stock JK 18in wheels w/ Spydertrax 1.25in spacers and 32in toyo at, 2.5in RC lift with .5in shackles(BESRK), rear TJ flares. 8.8 rebuild soon
BIGJoe29 is offline
post #2 of 7 Old 11-05-2011, 03:28 PM
scubamc
First you will need to flex it out to see how much bumpstop you will need to add. You can buy extended stops or weld some extensions in.
scubamc is offline
post #3 of 7 Old 11-06-2011, 02:10 AM
leeejone
When I was painting my undercariage a couple of months ago I noticed that I only actually had one bumpstop (front right) and that the others were completely rusted away. Should I replace them? I don't do any offroading that really flexes that much. *shrug*
1995 2.5 Low Output Auto
leeejone is offline
post #4 of 7 Old 11-06-2011, 05:19 AM
RockOn93
Bumps stops are not a high ticket item to replace. Even if you don't do "any off roading that really flexes that much"... you are smart to have them. Bump stops benefits well documented. Spend a little $ now to safeguard from breakdowns and costly repairs later. I hate to be this guy BUT do a search and checkout the posts on this topic.
RockOn93 is offline
post #5 of 7 Old 11-06-2011, 05:44 AM
Jeepfan1
I have the exact same problem on mine just havent decided my course of action
Instead of being a parrot and repeating the" do a search" routine like a bunch of others how about you share what you found thats well documented, otherwise their is no reason for a discussion forum we will all just reference back to the site via a search that doesnt work and never mix and mingle
/l , [____],
|---L--OlllllllO-
()_) ()_)==O=)_)
Jeepfan1 is offline
post #6 of 7 Old 11-06-2011, 06:38 AM
RockOn93
Instead of being a parrot and repeating the" do a search" routine luike a bunch of others how about you share what you found thats well documented, otherwise their is no reason for a discussion forum we will all just reference back to the site via a search that doesnt work and never mix and mingle
You're right. I should have taken the time to provide links and details on the risks of running without bump stops. Please excuse me for being lazy and not going the extra mile to answer this post more throughly. I appericate you taking the time to point out the errors of my ways. If more people would call out people like me, this would be a better place to gather information and/or mix and mingle. I will certainly re-double my efforts to improve my content and become a better forum partcipant. Thank you.
RockOn93 is offline
post #7 of 7 Old 11-06-2011, 12:45 PM Thread Starter
BIGJoe29
i really dont know wat to measure or look for though
BIGJoe29 is offline
bilstein , bump stop , shock , suspension , YJ
spare tire bump stop extension ? ADIDAS TJ Wrangler Technical Forum 12 09-29-2011 07:02 PM
Bump stop extenders pushing past Bump stops. KraZeDav YJ Wrangler Technical Forum 5 09-12-2009 03:57 PM
Size of Bump Stop Extension? HAARUBICON TJ Wrangler Technical Forum 2 03-24-2009 07:57 PM
How long front bump stop extension with OME lift? saxart TJ Wrangler Technical Forum 12 03-08-2008 05:36 PM
bump stop extension brackets YJinSD YJ Wrangler Technical Forum 1 01-31-2004 08:56 AM
