bump steer...do I need a trac bar? - JeepForum.com
post #1 of 4 Old 11-11-2013, 04:34 PM Thread Starter
RAOTERO
RAOTERO's Avatar
Installed a Rubicon Express 7" SOA lift kit a few years ago and eliminated the trac bar after some advice from a shop in town. Now I'm having some serious bump steer. Do I NEED a trac bar?? It doesn't seem like I do since it was good for a long while before the bump steer issues came around
That being said, most forums talk about angles between the trac bar and drag link being the same in order to eliminate bump steer. Any advice?
'89 YJ
RAOTERO is offline
post #2 of 4 Old 11-11-2013, 05:17 PM
djwrangler
1997 XJ Cherokee
No need for the track bar with the leaf springs. That track bar/drag link alignment talk is for the coil spring guys. Sounds like a steering alignment issue to me. What steering setup do you have? Drop pitman arm? Over the knuckle setup?
djwrangler is offline
post #3 of 4 Old 11-11-2013, 05:18 PM
Mark05059
pictures of your steering setup will help us help you
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 4 Old 11-11-2013, 06:19 PM
Norcal_chris
Norcal_chris's Avatar
You have bumpsteer because of your draglink angle and length, and the inverted t style steering.
The flatter the draglink the less issues you will have. Also some pics would help.
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
