"Bump Bump Bump" when disengaging clutch - JeepForum.com
post #1 of 5 Old 06-11-2013, 09:45 AM Thread Starter
Rob_Feature
I've had clutch issues for the past few years and even had it replaced (which didn't appear to help anything) but here's the issue. I'm not even sure if it's the clutch itself, but am trying to diagnose.
When starting up in 1st gear and slowly releasing the clutch, there's a "bump bump" thumping feeling in the pedal. Sometimes (especially if starting up while turning) I also get a bit of a grinding feeling as well.
Something's not right...any ideas? Does this seem like a familiar clutch issue of some kind? Feel free to ask clarifying questions...not sure how else to describe it...
Rob_Feature is offline
post #2 of 5 Old 06-11-2013, 04:26 PM
OKwranglerYJ
I would start will all your drivetrain mounts, it is probably your drivers side motor mount.
OKwranglerYJ is offline
post #3 of 5 Old 06-11-2013, 05:48 PM Thread Starter
Rob_Feature
That actually seems to make some sense...long ago I swear I could feel the weight (engine?) 'slide' a little when cornering. People told me I was nuts, but I've been driving this car almost 20 years so I trusted my instincts that something was wrong.
Does it make sense I'd feel this in 1st but not once I got past 2nd gear?
post #4 of 5 Old 06-11-2013, 05:54 PM
OKwranglerYJ
Yeah first gear is the lowest gear so more torque is applied.
post #5 of 5 Old 07-17-2013, 06:57 PM Thread Starter
Rob_Feature
Just a quick reply...I've torn things apart to replace my clutch and found that, indeed, my passenger side motor mount was totally broken off. Good advice here, thanks for the help!
clutch , YJ
