-   -   bulb numbers (http://www.jeepforum.com/forum/f12/bulb-numbers-1547559/)
kjg26 07-10-2013 09:51 PM
bulb numbers
Anyone know the bulb size or numbers for the courtesy lights under the dash? How about the one that goes above the extra switch panel to the right of the column?
jokerchief462 07-10-2013 11:35 PM
194 is the dash lights is it the same???
djfred 07-11-2013 01:31 AM
Here is a list hope it helps
Heater Control Lamps = 194
Courtesy Lamps Under the Dash = 89
Hardtop Dome Light - Interior Rear = 212-2 (comes in pair)
Soundbar Dome Lamp = 578
4WD Indicator = 161
Engine Coolant Temperature Gauge = 194
Voltmeter Gauge = 194
Oil Pressure Gauge = 194
Fuel Gauge = 194
Tachometer = 194
Speedometer = 194
Indicator Lamps: Turn Signals, Fasten Seat Belts, Check Engine, High Beam, Park Brake & ABS = 74
The time now is 08:14 AM.
