building off stock rollbar, question about stock seatbelt mount - JeepForum.com
post #1 of 7 Old 09-02-2010, 03:26 PM Thread Starter
91YJRockCrawler
what should i do about the stock seatbelt mount? im not going to be needing it anymore because im mounting 5 point harness, should i grind it down? put the bolt back in it? thoughts?
The P.O.S: 91 wrangler locked on 33s
Daily Driver/tow rig: 01 F150
its mind over matter.. I donít mind and the sheet metal donít matter
Originally Posted by JeepnBlake View Post
It's JF's very own little slice of Pirate :rofl:
91YJRockCrawler is offline
post #2 of 7 Old 09-02-2010, 03:29 PM
ImpactFabWorks
I think it all depends on how much it bugs you. If you don't care leave, But I would cut it grind it and fill it with weld then grind it some more so you would never know it was there. what design are you going with on your cage?
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #3 of 7 Old 09-02-2010, 04:07 PM Thread Starter
91YJRockCrawler
would that make it weak? i was think about something like that but didnt want to make the b piller weak, i went with the A to Z fab. front cage it
post #4 of 7 Old 09-02-2010, 04:13 PM
ImpactFabWorks
it wouldn't be any weaker than the fact that tube already has a hole in it. It's only a half inch hole so you shouldn't over heat anything enought to compromise strength.
post #5 of 7 Old 09-02-2010, 04:28 PM Thread Starter
91YJRockCrawler
alright cool, thanks alot
post #6 of 7 Old 09-02-2010, 05:23 PM
TSEJEEPERS
I would throw a stainless bolt in it and leave it.
KISS
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #7 of 7 Old 09-02-2010, 07:45 PM
BigBass
Find something else to hang there. I don't know what off the top of my head but it seems there should be something practical to put there.
All Long Islanders Check out OutLawedOffroad.com throw my user name BigBass in the referral box
BigBass is offline
what's stock rollbar OD mascun TJ Wrangler Technical Forum 3 01-07-2009 08:24 PM
TJ - Diameter of the Stock rollbar? Unscathed TJ Wrangler Technical Forum 5 11-16-2007 11:36 AM
Stock Spare Mount Question Windwalker JK Wrangler Technical Forum 2 02-25-2007 09:53 AM
Seatbelt Harness On Stock '03 Seats jbpdog TJ Wrangler Technical Forum 7 07-13-2005 12:41 PM
Stock seatbelt not staying latched Rastahmann TJ Wrangler Technical Forum 4 02-03-2004 07:29 PM
