Building my yj - Page 3 - JeepForum.com
post #31 of 53 Old 03-27-2009, 07:41 PM Thread Starter
EZAces
Started to put my SYE in and when i pulled the cace apart found little parts a screw a snap ring and lots of filings. So that was the end of that praject 550 dolors later i got the parts orderd.
EZAces is offline
post #32 of 53 Old 03-29-2009, 12:24 AM Thread Starter
EZAces
Replaced the 3inc body lift with a 1 inc and ready for the engin test fit
EZAces is offline
post #33 of 53 Old 03-29-2009, 12:37 AM
jsahara24
sounds like your making some good progress.... howd the transfer case go??
99' Jeep Cherokee Sport
07' Toyota Matrix
jsahara24 is offline
post #34 of 53 Old 03-29-2009, 10:53 AM Thread Starter
EZAces
still waiting on parts to come in for the transphere case. ghopefully wensday
EZAces is offline
post #35 of 53 Old 03-30-2009, 09:49 PM Thread Starter
EZAces
I cut out the factory motor monts and did a fast test fit. With the test fit I can see where and how to fab up the new motor monts. Its not as tight as I thought it would be, but may have an isue with the exast manifold and have to get headers.
LOTS and LOTS of wires to hook up
should have room for eletric fans
Looks nice at this ange.
EZAces is offline
post #36 of 53 Old 03-30-2009, 10:36 PM
provinT13
Where are you in Colorado?
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #37 of 53 Old 03-30-2009, 10:41 PM Thread Starter
EZAces
just over Medano Pass from you by Alamosa
EZAces is offline
post #38 of 53 Old 03-30-2009, 10:44 PM
provinT13
Ah when do you plan to have this beast up and running?
post #39 of 53 Old 03-30-2009, 10:50 PM Thread Starter
EZAces
mid june is the planed time frame
EZAces is offline
post #40 of 53 Old 03-30-2009, 10:51 PM
provinT13
Nice, hopefully we can catch a few trail runs together, that's about the time I plan to have my 8.8 and locker in.
post #41 of 53 Old 03-30-2009, 11:14 PM
jeffreyperria
i put one of those 2006 5.3 vortec v8's in my jeep. that thing runs balls out. i even blew a ricer out of the water with it. so i know that 5.7 should give you some balls
jeffreyperria is offline
post #42 of 53 Old 04-14-2009, 10:49 PM Thread Starter
EZAces
I installed my SYE and rebuilt the transphercase.
Before
After
Full write up is
http://www.jeepforum.com/forum/f12/np-231-j-rebuild-sye-install-748821/
EZAces is offline
post #43 of 53 Old 04-14-2009, 10:51 PM
YJSlave
This thing is going to be nasty! Does that D44 have the cast wedges or bolt on?
YJSlave is offline
post #44 of 53 Old 06-10-2009, 09:47 AM Thread Starter
EZAces
Got the axles pulled apart and the lockers on the way. pulled every electrical wire out of the jeep. only thing left in it is the roll bar. will load pics later. the only parts left to buy is the tubing for the cage and the rims and tires. will post lots of pics of the Assembly. Bought a belt driven composer made just for compersing air, Lubed by a grease Zerk.
EZAces is offline
post #45 of 53 Old 06-11-2009, 10:42 PM Thread Starter
EZAces
The engine is now mounted have to get a deferent trans mount when i can get to town. Now to route all the spaghetti and test fire up the engine.
EZAces is offline
need help building YJ usmc1009 YJ Wrangler Technical Forum 13 11-29-2009 09:57 AM
Is building a D35 really that big of a no-no? Mol YJ Wrangler Technical Forum 36 09-13-2009 12:22 AM
Building my YJ Chisow YJ Wrangler Technical Forum 12 04-10-2009 07:34 PM
Building up my YJ wessy YJ Wrangler Technical Forum 2 09-12-2008 12:13 PM
Building a 44 advtj TJ Wrangler Technical Forum 11 03-10-2004 06:55 PM
