Building a Jeep ground up - JeepForum.com
post #1 of 7 Old 07-25-2003, 08:58 AM Thread Starter
biohazardbill
Ok... here is something i have been pondering. Any views, or opinions appreciated. I bought a 92 Yj and i keep reading and looking into what i want to do etc... new tub, new frame (maybe) lift kit, dana axles etc. Well if i do this i will be left with a whole bunch of parts. I was thinking instead of building up the jeep i have build a new jeep from the ground up. I mean theoretically i will doing it anyway so in doing it this way i can at least know everything is done correctly and new. Then with my existing Jeep keep that to play with. Question is, is this actually a good idea... and if so how would i title such a vehicle so i can use it on the road?
Bill
biohazardbill is offline
post #2 of 7 Old 07-25-2003, 10:18 AM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
Sounds like a plan to me. Most of us would do that if we had the money, time, and space to do it in. I know I would.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #3 of 7 Old 07-25-2003, 10:41 AM Thread Starter
biohazardbill
I read somewhere on here about a guy that builds or has access to good jeep frames... anyone know who that may be... and its not like im rich lol i would still be buying stuff one piece at a time just like for my current jeep
post #4 of 7 Old 07-25-2003, 11:27 AM
johnny1720
johnny1720's Avatar
IMO
BIOHAZADBILL,
That would be the ultimate thing to do is get a good frame and work from the ground up. But IMO you would need some sort of a base or donor jeep. You will find out that you dont want to find every single little part #1, and #2 that you you dont want to pay for every single little part. I am planning on purchasing an additonal 91 or newer jeep to do just that build from the ground up.
what ever you choose good luck and it will be fun. Jeeps are fairly simple to work on all you need is a lot of ambition. And the abilty to read and comphrend.
04 TJ
Warn 9.5ti, Tomken Winch Plate
Rusty's 2 Inch Coil Lift, JKS 1 1/4" BL and MML
LOD Swing Away Tire Carrier
B&M Short Throw, Rear Alloy USA Axle Shafts
33x10.5x15 BFG AT's
johnny1720 is offline
post #5 of 7 Old 07-25-2003, 03:13 PM
socalchef
you title the frame...so if you find a good condition old frame you can build it up with new parts and make it smog exempt..depending on where you live
Shaffers Diablo Sport chassis on a 4.0L YJ frame
Radflo shocks and coilovers, Superior d30 shafts and Super 88, 36" Iroks, Atlas tc,
socalchef is offline
post #6 of 7 Old 07-25-2003, 09:21 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Find a Jeep that has been crunched, burned or otherwise written off by the insurance company.
To build a Jeep from scratch (well, almost) the only parts that you would really want is the frame (maybe for reference when you build your tube frame), the front grill, and parts of the tub. Everything else doesn't really need to work as you would be putting in Dana60 axles, 454ci Chevy power, full-cage tied to (or part of) your frame, racing seats tied to your cage with full 5-point belts .. and so on and so forth
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #7 of 7 Old 07-26-2003, 09:33 AM
mudflap69
What I did was just take my 92 yj off the road and started stripping it down to the frame. Then started putting it back together with the parts I wanted. It is alot of work and very time consuming project. A place to work and store your parts will become a issue. I have a 22 X 24 garage to work in then I have an 8 X 10 shed to store parts in. It is nice to see things go back together just the way you want them. And another thing.... throw the budget out the window. Here are a few pics of my project and a few parts I made along the way.
http://home.cogeco.ca/~rdocherty/jeep%20pics.htm
90 XJ stock
92 YJ in a thousand pieces in the garage.
mudflap69 is offline
i need help with my building my jeep lilbluetj Wrangler General Discussion 1 12-23-2009 12:12 AM
Building a Jeep Book? TNNewbie YJ Wrangler Technical Forum 3 08-17-2009 01:01 PM
Building my first Jeep mhn1961 YJ Wrangler Technical Forum 32 05-29-2008 04:32 PM
building a jeep wessy YJ Wrangler Technical Forum 3 03-02-2007 06:46 PM
Building my Jeep wessy YJ Wrangler Technical Forum 8 01-12-2007 06:07 PM
