Build Thread - Peugeot BA10/5 to NV3550 - Page 3 - JeepForum.com
post #31 of 49 Old 02-09-2007, 04:04 PM Thread Starter
northjeep
Jeep parking ONLY
northjeep's Avatar
Originally Posted by YJ-Mike
North,
Great to hear that everything ended up working out for you. What fluid did you end up running in the 3550? I am getting to the point where I am about to start the thing up (hopefully), and I need to figure what fluids I am going to run.
Thanks
First I tried mopar "for nv3500" stuff...then I tried (get this) 10w-30 motor friggin oil for about 20 miles.....then I flushed and filled with royal purple synchromax. All of the fluid switching was to eliminate the shifting problems I was having. RP Smax is good stuff....pricey up here, but good.
Originally Posted by tcourdin
Good write up Northjeep! I did the same swap at about the same time you did (as you know) . I havent even put 500 miles on the Jeep since the swap but I absolutely love that nice new NV3550 when I do get to drive it! If anyones going to swap out trannys its the way to go.
Thanks for the props tc.
I totally recommend the 3550 for any 6 cyl application...and some 8's.
The tranny is wonderful to work with given it's 100 lb weight and 300 lb/ft capacity.
-NorthJeep - >> Just Enough Essential Parts
northjeep is offline
post #32 of 49 Old 02-09-2007, 04:32 PM
YJ-Mike
Several others have recommended synchromax so I guess that is the way I will go.
Thanks
Mike
2006 TJ X (Stock - w/ Borla Cat-Back Exhaust)
Built a YJ from the ground up:
- '04 4.0L (4,000 miles), NV3550 (0 miles), NP231 w/ HD SYE (9,000 miles), 33x12.50x15 Pro-Comp AT's, HP D30/8.8 (4.56 gears), ARB Lockers front and rear w/ compressor, hard/soft tops, full/half doors.
-----> Build thread can be read here:
YJ-Mike is offline
post #33 of 49 Old 04-08-2007, 02:22 PM
Morgsie
Does anyone know if the Chevy bolt pattern NV3500 is a similar swap? Looking to swap a 305 V8 or 4.3 V6 mated with a chevy NV3500, but want to retain the Jeep's NP231. Beside the bell housing are all NV3500s the same? Or will I run into other problems using a chevy NV3500 with a Jeep NP231?
Also when buying an NV3500 does it have to be a 4x4 one? And if it's a 2WD on, will I need a new output shaft (ie: shorter)?
Morgsie is offline
post #34 of 49 Old 07-24-2008, 02:02 PM Thread Starter
northjeep
Jeep parking ONLY
northjeep's Avatar
I just made all the pictures work again...
Update to the thread:
Very happy with the trans it's as tight as can be and sooooooooo strong I have beat the piss out of this thing and it just scoffs and says "awwww.....little boy got happy on the skinny pedal?!" and I say "YES! take it take it take IT!"...and it does....as it scoffs.
post #35 of 49 Old 04-14-2009, 07:28 AM
photoboy74
Write Up.
This is a great write up, just like Richmond88YJ's ax-15 swap. Having not done a tranny upgrade before, your attention to detail in both articles was a tremendous help. I was going to do an AX-15 first, but the NV dropped in my lap with a great deal.
I'm in the process of doing the NV3550 swap with my 88, and took a slightly different approach.
First, I purchased the NV3550, NP231, rear driveshaft and slave cylinder used from a 2001 TJ. I couldn't use the master cylinder since the brake booster on the 88 is in the way to fit the longer one.
Afterwords, a quick call to Advance Adapters and talking to a great team there, I ordered the following parts to complete the transition.
  1. 716130TJH - Slave cylinder hose kit with the fitting to connect to the 88 master cylinder.
  2. 716164 - pilot bushing to make room for the NV3550.
  3. 715515 - shifter bracket to reuse my t-case shifter from the old NP231.
  4. 716007 - Crossmember mount kit to reuse the muffler mount.
All I needed to do was swap out the speedo gear and connector on the newer NP231 since the 88 doesn't use the electronic speedo. This saved me a lot of time from changing the input shaft on the old t-case.
One weekend later, and the Jeep is shifting great. Now I just need to get rid of the old tranny and t-case!
photoboy74 is offline
post #36 of 49 Old 04-19-2009, 03:24 PM
photoboy74
Pilot Bearing
So is there a better way to get the pilot bearing out without having to buy the Harbor Freight tool? I rented a pilot bearing puller from Autozone, but it is too big to fit in the I/D of the old bearing.
I tried greasing the back end, but had no luck. Of course I was told later that this method doesn't work on bearings, just pilot bushings.
So I'm toying with the idea behind using a hack saw, but I'm wondering how effective it would be with only being able to saw an inch, if the blade will even fit.
post #37 of 49 Old 04-19-2009, 03:45 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Added to the FAQ, very nice write up man.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #38 of 49 Old 05-05-2009, 04:54 PM Thread Starter
northjeep
Jeep parking ONLY
northjeep's Avatar
Thanks rusty!
post #39 of 49 Old 05-08-2010, 09:24 PM
MosesYJ
1987 YJ Wrangler
hey im getting ready to do this exact same swap into an 87 yj, i need to know EVERYTHING it takes to do the swap, i.e. pilot bearing?, internal slave to external slave? bell housing? any thing else
thanks for all the help,wonderful writeup by the way
MosesYJ is offline
post #40 of 49 Old 05-08-2010, 09:51 PM
moonshinefuel
Holy Moses! Almost exactly a year after northjeeps last post, this great transmission faq is revived, and bumped to the top again. Of course you know anything with an NV3550 gets immidiate attention.
moonshinefuel is offline
post #41 of 49 Old 05-09-2010, 10:16 AM Thread Starter
northjeep
Jeep parking ONLY
northjeep's Avatar
A complete list with part numbers...AND EVERYTHING.
Well I suppose I never included that in my build info.
'92-'99 AX15 and NVG3550: OEM pilot bearing 53009180AB for '87-'91 engine
Advance Adapters Bell housing kit incl release lever, throwout bearing and pilot bearing p/n 712590
(P/N 715545) NV3550 Shifter Bracket (for Jeep NP231 transfer cases)
23 spline transfer case input conversion
(P/N 716007) NV3550 Crossmember Mount Kit (for Jeep YJ Wranglers)
(P/N 716340) Jeep Slave Cylinder Kit For NV3550
Clutch components: Your stock pressure plate and clutch disc will work. Now is a good time to replace them unless they are known to be good.
post #42 of 49 Old 08-07-2010, 05:49 PM
OMAHA1980
do you think the 3550 can handle a stock 5.3 ls? if not the 4.8? is there any real difference in 10-20 ft-lbs?
OMAHA1980 is offline
post #43 of 49 Old 04-22-2011, 10:48 AM Thread Starter
northjeep
Jeep parking ONLY
northjeep's Avatar
Having put some hard miles on this trans I can say it will stand up to slot of power and torque. It would probably hold back a big block if you didn't flog it too hard.
post #44 of 49 Old 04-22-2011, 11:31 AM
pushead
Just a fyi your tranny is not new it is rebuilt. I was going to buy one from High Impact a few years ago myself. Call them and ask if you feel I am incorrect. The only reason I did not end up buying from them is I found a nv3550 with 20k miles that was swapped out for a new tranny motor combo for $400.00.
Its not a jeep if it dont have 4wd.
pushead is offline
post #45 of 49 Old 12-10-2011, 04:41 PM
argo77
1987 YJ Wrangler
Hey man, when you installed NV3550 into 6cyl engine, did you have to buy slave cylinder, pilot bushing, and clutch plate for that tranny? Did you have to switch the flywheel? Thanks for your help.
argo77 is offline
87 88 89 yj wrangler , nv3550 , part numbers , peugeot ba10/5 , transmission swap
Peugeot BA10/5 leaking fireshadow YJ Wrangler Technical Forum 5 11-13-2009 07:07 AM
BA10/5 to NV3550 Swap photoboy74 YJ Wrangler Technical Forum 1 06-15-2009 11:56 AM
ba10 to Junkyard nv3550 On 87 YJ MaineYJ YJ Wrangler Technical Forum 23 06-15-2009 11:55 AM
5.3 nv3550 thread?? slafferty TJ Wrangler Technical Forum 0 02-16-2009 12:20 PM
Oil capacity for Peugeot BA10 Tranny 87YJWrangler YJ Wrangler Technical Forum 4 03-25-2006 08:13 AM
