Budget Junkyard Upgrades. - Page 9 - JeepForum.com
post #121 of 134 Old 12-28-2013, 12:48 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Originally Posted by PETE-4D
New here,,, reading some of the comments on the fuel tanks,,, I did this modification on mine a few weeks ago 15-gallon to a 20-gallon tank, I had a quarter of a tank and topped the tank off with 14.2 more gallons. Drove over 140 miles before the gauge moved off full. Hers the link for the modification. http://www.4x4wire.com/jeep/tech/fuel/15to20gal/
That's cute. Here's the /f12 FAQ mod thread on that subject http://www.jeepforum.com/forum/f12/a...2-hour-516115/
Posted via my pretentious iPhone.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #122 of 134 Old 01-04-2014, 10:15 AM
Jstout724
I think your avatar is cute. Is that you?
Jstout724 is offline
post #123 of 134 Old 01-04-2014, 10:21 AM
Luuca
Luuca's Avatar
Wrong site. You wana start here http://www.farmersonly.com/
YJOTM never
Luuca is offline
post #124 of 134 Old 01-04-2014, 11:03 AM
Loomie
MWAHAHAHAHAHAHAHAHAHA!
Loomie is offline
post #125 of 134 Old 01-04-2014, 07:19 PM
AmmitOsiris
Originally Posted by Luuca
Wrong site. You wana start here http://www.farmersonly.com/ Posted via my pretentious iPhone.
I've been seeing that on the television lately.
Lol
DISCLAIMER: YOUR ACTIONS ARE CURRENTLY BEING MONITORED.
AmmitOsiris is offline
post #126 of 134 Old 01-05-2014, 02:32 AM
Jstout724
Maybe I could find a cute farm boy picture to post as my Avatar!!!
Then I could tell people their posts were cute.
post #127 of 134 Old 01-05-2014, 02:34 AM
Jstout724
Was just poking some fun, while trying to bump this thread on Junkyard upgrades. Would like to see some of the latest JY upgrades, Im working on some now that I am going to post soon.
Mwahahaha-huh?
post #128 of 134 Old 06-01-2014, 10:35 PM
mooncruiser
Originally Posted by MrPoot View Post
With so many people having issues with the oem gas tank in regards to the fuel float/gauge, has anyone found a nice solution for this other than taking the plastic cup out? (I'd hate to not be able to get fuel if I'm on an incline.)
Is there a better sending unit I can use that is less likely to screw up? Different tank altogether perhaps?
When I replaced my pump I took a razor knife and trimmed the plastic cup (cut like butter) and now my float can go all the way down to E. No more worrying about running out of gas at 1/4 tank rading.
93 YJ - 2.5 5spd, NP231 tcase, SYE, CV driveshaft 7"slip spicer, 2.5" Old MAn Emu 36r's all 4 corners, Bilstein 5100's, 4.10 f & r , Posi-Lock front axle, Tuffy boxes, MM winch.
mooncruiser is offline
post #129 of 134 Old 07-16-2014, 08:46 AM
deogsxr
I pulled an 8.8, XJ front drive shaft, TJ D30 shafts, and a taurus fan not to long ago. I got lots of work to do lol
*1995 YJ, 4.0l 5 speed.
*2006 Dodge 2500 5.9l Cummins Twin Turbo
*2010 Infiniti G37xS (SOLD)
deogsxr is offline
post #130 of 134 Old 04-10-2015, 10:23 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Originally Posted by jdubsjeep View Post
136 amp alternator off a Grand Cherokee, late 90's. Replace positive cable fitting with your old one and direct bolt in. Helps to upgrade grounds and battery cables.
I thought I'd add to this. Since I just posted it on another thread.
Que89YJ posted this a few years ago. He was able to restore it from a long dead link. I think he used the DeLorean.
I did it to my '94, and it was a piece of cake. You should just double-check that your Jeep has the same alternator.
Originally Posted by Que89YJ View Post
Dont just repair, make it better:
This is from BC 4x4. I have included the pics in the end. It seems the link for this post was severed and the only way I could get it was the way back machine:
PRELUDE
OK, for some time now, I was wanting to add an electric fan to my beast. I was really wanting to install one of the 91-95 3.8L Taurus dual-speed fans that is all the rage these days. The only problem with this was the 33A continuous draw and 100+A startup draw. So, that meant that the stock 90A alternator would be working its tail off. The only other option that I had, besides the out-of-the-question USD$300+ hi-amp alternator upgrade, was to purchase a decent aftermarket fan that drew only around 10A or so continuous. The problem with this is that these fans are not cheap. So, I went on a mission to find a replacement hi-amp OEM alternator. I read about people looking at 120 amp models and one mention of a 136 amp model but nobody, as far as I know, ever confirmed that any of these would even work on paper. Guess what, for a mere USD$30, I was able to upgrade to a 136 amp alternator with very, very little effort! You say this can't be true. Well folks, it is and I am about to show you!
WHAT YOU HAVE
Here's a photo of my original alternator. Ok, now, I know that the OEM 90 amp alternator(OEM PN:56005685AB) in my 97 TJ was also used in the following:
  • 1997-1998 Dodge Dakota
  • 1991-1998 Jeep Cherokee
  • 1991-1992 Jeep Comanche
  • 1992-1998 Jeep Grand Cherokee
  • 1991-1998 Jeep Wrangler
Note: I have only confirmed this entire modification on a 1997 4.0L Jeep Wrangler. I am unsure as to what motor combinations the above vehicles came with in conjunction with this particular 90A alternator. This is an "ON YOUR OWN AND YOUR OWN RISK" type of modification. If your wiring is not up to the task, etc., you could burn your jeep to the ground or injure yourself. YOU HAVE BEEN WARNED!!
WHAT YOU NEED
Here's what you're looking for. You are looking for an OEM 136 amp alternator(OEM PN:56027913) that was an option on the following vehicles(I am unsure of what motor combinations, etc. were required):
  • 1997-1998 Dodge B.Series Van
  • 1998 Dodge Durango
  • 1997-1998 Dodge Ram Pickup
  • 1997-1998 Jeep Grand Cherokee
I got mine from a local Jeep yard for USD$30 out of a very clean 98 5.2L Limited that only had 60,000 miles on it when it was wrecked.
Here are the two alts. side by side. The higher amp. alternator is on the left.
I did quite a bit of research and found that the basic mounting dimensions and connections were the same between the two. You can see the physical size difference of the two. As a matter of fact the 136A alternator was 1 kg heavier. The only major difference was the direction of the plastic boot on the back of the alternator and the pulley is a 7 groove vs. my TJ's 6 groove. It was found that there was a 1 mm difference between the pulley diameters, but this is negligible and does not need to be addressed.
WHAT YOU NEED TO DO TO INSTALL
Ok, this mod is not much harder than installing a new alternator. I won't go into the details of changing the alternator, but rather, I will point out the details that must addressed during installation.
The first major difference between the two is the direction of the plastic boot. For ease of installation and clearance, this needs to be changed. By swapping the boots from the Wrangler to the Cherokee alternator, this change is easily accomplished. The boots are keyed (see red arrows) and install over the indicated stud below and locate on the small hole in the case (see green arrow).
The Wrangler boot is on the left and directs the exit of the boot away from the engine.
Details of the plastic boot positioning.
The other very minute detail to be attended to was the "spacer bushing" on the rear ear of the top alternator mount. The Cherokee's alternator's bushing (probably from rolling around on the floor) had been pushed too far inward and needed to be pressed back out. I accomplished this via a vise and large socket. Don't worry about pressing the bushing too far out because the mounting bolt will draw the bushing back tight again. The picture below shows the bushing after I pressed it out of the way:
The spacer bushing.
Finally, I mentioned that the Cherokee's pulley was a 7 groove pulley. If you wanted the extra work, you could simply swap the two alternators' pulleys. However, you do not need to do this. If you bias the belt to the rearward most six grooves, the belt and alternator will align and run just fine. You can see the alternator installed in the pic below with the belt biased towards the back.
Installed and ready to go. Notice how that the front groove on the pulley is unused.
Well, after the install, I tested the bad boy out. Everything seems to work just fine and I can crank the old stereo and run every electronic device in my jeep and hook up the Taurus fan to the battery and nothing even "blinks." Anyway, hopefully, someone will find this article helpful and save a few dollars in the process.
- Tod "Firetoad"
And this thread:
http://www.quadratecforum.com/showpost.php?p=871966
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #131 of 134 Old 04-10-2015, 10:32 AM
BrutalTim
Anyone know if this will work with an 89' 258 with serpentine belt?
Tim
Last edited by BrutalTim; 04-10-2015 at 10:38 AM. Reason: Opps... Just relized this is a sticky thread.
BrutalTim is offline
post #132 of 134 Old 04-10-2015, 01:36 PM
dancytron
No, different system. For an '89 you need a Chevy type internally regulated alternator. Like a CS130 or CS144.
dancytron is offline
post #133 of 134 Old 04-11-2015, 05:26 AM
BrutalTim
Got ya Thanks
Tim
post #134 of 134 Old 10-20-2015, 11:01 PM
whokenstad
Ok heres my list of winter projects
-Dana 30 junkyard parts 95-99 XJ axle shafts to do a CAD delete
-Transfer case vacuum switch replaced with electrical switch from xj (maintain 4wd light)
-Replacing exhaust (manifold cracks) and going to be doing a TJ downpipe for better ground clearance
whokenstad is offline
Budget Junkyard Upgrades cubbie TJ Wrangler Technical Forum 757 01-19-2015 04:35 PM
budget/junkyard cv driveshafts, who runs them? Do you like? snowrydr01 TJ Wrangler Technical Forum 42 05-27-2011 10:48 PM
ZJ Tie Rod, Durango Steering box, other junkyard upgrades/mods BWFBezerk TJ Wrangler Technical Forum 2 03-11-2009 03:16 PM
JunkYard Mods or Upgrades JeepinNH YJ Wrangler Technical Forum 3 03-31-2002 04:32 AM
