Budget Junkyard Upgrades. - Page 6 - JeepForum.com
post #76 of 134 Old 03-28-2013, 06:45 PM
Louie4
Originally Posted by Rookie-IA-YJ View Post
ok the part i am looking for seems like it would be a easy find but is turning out to be a bit more difficult than i thought i am looking for some kind of junction box that is water proof and i can mount under hood to condense all the accessory power wires down to just one wire going from battery to junction box and then to their respective place. any ideas would be a big help thanks
Maybe a Dodge Neon power distribution pack.
http://www.jeepforum.com/forum/f12/3...0-less-861374/
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #77 of 134 Old 03-28-2013, 07:01 PM
bgredjeep
1987 YJ Wrangler
I'm working on a serpentine belt swap in my yj. Found a 4cyl Comanche (late 80s) and noticed the power steering bracket appeared to match the available mounts on my 4.2. It was a non- AC truck which is what I needed. I ended up grabbing the power steering pump and bracket, alternator bracket, and water pump pulley.
Once I'm done it won't be much of a budget swap since I'll be installing a new water pump, PS pump and alternator. I'm actually surprised I've never seen any mention of this swap since the parts match so well.
bgredjeep is offline
post #78 of 134 Old 03-28-2013, 08:36 PM
Louie4
I figure I would post this since it's pretty cheap. I was at the junkyard looking for Cherokee or Grand Cherokee front driveshafts so I could change over my current flange style connection on my Tom Woods rear driveshaft to the yoke style. While I was out there I got a wild hair and started pulling speedometer gears out. I started finding that they were different colors then saw the tooth count stamped in them. I vaguely remember looking at a chart for my 33" tires and 4.10's and remembered it being around 36 so I started collecting them.
The dark green has 33 teeth, red has 35, and the orange has 36. The yellow is my stock 30 tooth count. When I came home I looked at the chart and found that I needed a 35 tooth to correct my speedometer so I simply unbolted the adapter/sensor pulled the old gear out and stuck the new one in. When I put the adapter/sensor back in I had to clock it so it would accept the new larger speedometer gear. It's a pretty simple and I know many of us have modified the tire size and gear ratios but the speedometer is usually not messed with especially when they are $30 buck or more (at least for me).
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #79 of 134 Old 03-28-2013, 09:41 PM
bigbossd1030
Here's mine, not quite done yet but close. It's a stock roof rack from a 98 XJ. I ended up having to make it a bit smaller for obvious reasons. On the rails (non movable pieces) I took off 8 1/2" on each end, to keep from having to drill any holes. If I took off 17 from one side, the holes wouldn't have been even. Now for the cross member pieces. I took off 7", this time only off one side. I put the piece on a table and traced out the curve. I then moved it along the trace mark 7" from center. The curve was the same all the way down. This way, it wouldn't look lopsided when mounted. Here are some pics, it's not bolted yet. Should have it done Friday. Oh and 20 bucks at pick and pull Edmonton for the roof rack (they call it a large luggage carrier). Oh and the XJ curve is almost a perfect fit to the YJ.
image-2202878290.jpg   image-1861754253.jpg   image-4101114574.jpg   image-1282991031.jpg   image-2847546190.jpg
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #80 of 134 Old 03-29-2013, 03:41 AM
USMCBuckWild
Some great ideas in here!
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #81 of 134 Old 04-14-2013, 07:31 PM
102joe
Originally Posted by motodad View Post
high steer knuckles and bigger brake kit for the dana 30 off of a WJ
I like the sound of this
Got any pics of this , what year WJ ? how common are they in the wreaking yard ? Or can you get OEM parts from a supplier ?
While I'm asking a ton of questions . Does any one have any budget up grades for YJ steering linkage ??
REAL JEEPS HAVE LEAF SPRINGS
NO REALY ,, IT IS HIP TO BE SQUAIR
102joe is offline
post #82 of 134 Old 04-14-2013, 10:43 PM
Nickabis
Click to View Search Results for Google (Search Results) Google (Search Results)
There are some good write ups and info.
Nickabis is offline
post #83 of 134 Old 04-15-2013, 03:46 AM
USMCBuckWild
This thread is pertinenet to my interests
post #84 of 134 Old 04-15-2013, 06:19 AM
grandboost98
I really like that XJ roof rack mod. Im going to see if you of the guys in the club has an extra theyre willing to get rid of nd make one for myself. Im thinking a little wider though.
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #85 of 134 Old 04-15-2013, 08:06 PM
bigbossd1030
I would have gone a little bigger but I have just enough room for my coffee cup in the morning when I open my door. It's nice having a roof rack again.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #86 of 134 Old 04-16-2013, 05:34 AM
grandboost98
Wait, whats the roof rack have to do with a cup of coffee?
post #87 of 134 Old 04-16-2013, 07:36 AM
bigbossd1030
Lol, when I come out in the mornings I put my coffee cup on the roof to unlock my door. You said you would go a bit wider, I was just giving an example of how much wider you could go.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #88 of 134 Old 04-16-2013, 07:37 AM
grandboost98
OHH alright, I gotcha. Still kinda early, need another coffee
post #89 of 134 Old 04-16-2013, 08:04 AM
SeanB95YJ
you can place the cup on the inside of the rack
just don't do like I have a milion times and forget it's there as you drive away LOL
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #90 of 134 Old 04-16-2013, 08:19 AM
grandboost98
I dont lock my doors no its a none issue for me. Probably why I was confused at first lol
Budget Junkyard Upgrades cubbie TJ Wrangler Technical Forum 757 01-19-2015 04:35 PM
budget/junkyard cv driveshafts, who runs them? Do you like? snowrydr01 TJ Wrangler Technical Forum 42 05-27-2011 10:48 PM
ZJ Tie Rod, Durango Steering box, other junkyard upgrades/mods BWFBezerk TJ Wrangler Technical Forum 2 03-11-2009 03:16 PM
JunkYard Mods or Upgrades JeepinNH YJ Wrangler Technical Forum 3 03-31-2002 04:32 AM
