Budget Junkyard Upgrades. - Page 4 - JeepForum.com
post #46 of 134 Old 10-11-2010, 04:12 AM
VooDuuChild
I'm wondering if this thread could be made a sticky and have a mod clean out all the non-helpful posts, much like this post and then it's always there for reference....??????
VooDuuChild is offline
post #47 of 134 Old 10-11-2010, 06:13 AM
Djsthe1
There is another thread that is much longer than this one that would be a better sticky..
Djsthe1 is offline
post #48 of 134 Old 10-17-2010, 08:09 AM
jbolty
jbolty's Avatar
Most recent find.
$2 truck loading dock bumper instead of a $35 winch saver.
jbolty is offline
post #49 of 134 Old 10-17-2010, 09:29 AM
r00ster
pitman arm
Originally Posted by VooDuuChild View Post
If I remember correctly, stock ZJ pitman arms are the same as three or four inch drop pitmans for Wranglers.
A stock XJ pitman arm is the same as a drpo pitman arm for a wrangler also.
r00ster is offline
post #50 of 134 Old 03-22-2011, 09:09 AM
GilNewJeeper
2008 KK Liberty
Originally Posted by jbolty View Post
This setup is good but I'm doing the following since I'm putting the full corner guards:
Did you Hug your Jeep today?
2008 Jeep Liberty
1994 Wrangler Sahara
GilNewJeeper is offline
post #51 of 134 Old 03-30-2011, 07:12 AM
GilNewJeeper
2008 KK Liberty
Got it!!!..... $50 at the bone yard
2008 Jeep Liberty
post #52 of 134 Old 04-30-2011, 02:02 PM Thread Starter
ChrisNukemYJ
Did you have to do a lot of reinforcement on the corner when you mounted the carrier so it wouldn't rip out or collapse the corner where it is mounted?
_____
/| ,[___],
|--L -[]lllll[]-
()_) ()_)-o-)_)
ChrisNukemYJ is offline
post #53 of 134 Old 06-06-2011, 12:50 PM
MrPoot
With so many people having issues with the oem gas tank in regards to the fuel float/gauge, has anyone found a nice solution for this other than taking the plastic cup out? (I'd hate to not be able to get fuel if I'm on an incline.)
Is there a better sending unit I can use that is less likely to screw up? Different tank altogether perhaps?
MrPoot is offline
post #54 of 134 Old 06-06-2011, 03:57 PM
superj
dodge used holley carbs on their v8s in the 60s, 70s, and 80s that are the proper bolt pattern for out 4.2 intakes. the cars had them and in the 80s, the pick ups had them. they also used a rochester but the pattern is larger so make sure you get the holley two barrel and its a bolt on swap for the crappy electric carb that came factory for us.
the pic is of one from a 1973 coronet that i have for my 87
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #55 of 134 Old 06-07-2011, 09:21 PM
915kingwrangler
Also all the CAD system on xj are bolt on on yjs, i bought like five of them in a mega u pull, also the bench seat from 94 and up(i believe) rangers fit..cant think of anything else rite now...
915kingwrangler is offline
post #56 of 134 Old 02-18-2012, 01:51 AM Thread Starter
ChrisNukemYJ
bump.
_____
/| ,[___],
|--L -[]lllll[]-
()_) ()_)-o-)_)
post #57 of 134 Old 02-18-2012, 02:47 AM
CleverNameHere
This is the bad part of a small town.... SMALL-ER Junkyard (1) With outrageous prices and no Jeeps or other useful piecse, a swing away tire carrier is about $120 to your $50 and I have yet to see a newerish jeep in the Junk Yard at Bandon
Any thoughts on small town junkies??
Anything I can do with about 12 old Acclaims with half the stuff (if not more) ripped out??
CleverNameHere is offline
post #58 of 134 Old 02-18-2012, 06:36 AM
Djsthe1
Found it.. http://www.jeepforum.com/forum/f9/bu...grades-518873/
My bad that is a TJ thread...
Djsthe1 is offline
post #59 of 134 Old 02-19-2012, 12:42 PM
95-rio-pv5
My junk yard mods for my YJ.
CJ-7 swing out tire carrier $40 with YJ hood hinges $10 so the tailgait swings out like a YJ tailgate with new hardware and paint for a total $80
Two horns. My orgnial, second YJ stock horn free, wire harness to fit $3
Jeep logo that I glued to dash under the fuel gauge that came off a J10 pick up $3.
Out of a full size diamond plate tool box lid for $10 I made:
2 of each to replace the stock rubber peddals: e-brake, clutch, brake, gas
2 light brackets
1 set of rocker pannels
I should be able to scrap the leftovers and break even
Two dome lights that came out of two Toyota 4Runner to fit the light brackets $5 each both colors match the interiors
Floor board light, passanger side $2
YJ drivers side seat belt $20
Rear seat brackets that mount to the fender wall free
I would like to find a winch for cheap next.
I would post picks but not up to 25 posts.
95-rio-pv5 is offline
post #60 of 134 Old 02-26-2012, 09:31 PM
evanjeep
2011 WK
did this work?
evanjeep is offline
Budget Junkyard Upgrades cubbie TJ Wrangler Technical Forum 757 01-19-2015 04:35 PM
budget/junkyard cv driveshafts, who runs them? Do you like? snowrydr01 TJ Wrangler Technical Forum 42 05-27-2011 10:48 PM
ZJ Tie Rod, Durango Steering box, other junkyard upgrades/mods BWFBezerk TJ Wrangler Technical Forum 2 03-11-2009 03:16 PM
JunkYard Mods or Upgrades JeepinNH YJ Wrangler Technical Forum 3 03-31-2002 04:32 AM
