10-01-2010, 02:41 AM
#1
Budget Junkyard Upgrades.
I read this in the TJ forum....
Well, after reading a few other threads I have become more interested in budget junkyard upgrades. What I mean when I say "budget junkyard upgrades" are upgrades like installing a ZJ tie rod into a TJ or using ZJ coils in the front of a TJ. Just wondering some of the things others have come up with to upgrade their TJ's who are trying to save some dough.
I want to know what kinda stuff people can do for there YJ's that will be an upgrade but not cost an arm and a leg.
_____
/| ,[___],
|--L -[]lllll[]-
()_) ()_)-o-)_)
10-01-2010, 08:41 AM
#2
I've got a couple of different ones:
1) 95 brake booster upgrade...although its getting harder to find boosters. You're looking at about $100 for the booster, master cylinder, & proportioning value.
2) Gas tank upgrade....87s and 88s (and maybe 89s) only can with the 15 gallon tank. If you're like me and want to put as much time between gas stops as possible, upgrading to a 91+ 20 gallon tank is a good idea. I'm not sure what they run at junkyards, but its got to be a lot cheaper than the $400 price tag for a new one.
3) Roll cage upgrade....if you have the old sports style rollcage and want to better protect the rear section, then this is a must. I picked up my family style rollcage for $50. I haven't installed it yet, but I'd imagine it is pretty much a bolt on.
"ROADS! Were we're going, we DON'T need roads!"
fuzz2010: "real jeeps don't have round lights, they have leaf springs"
tricked919: "Basic rule of thumb for me is if I see a front pumpkin, I give a wave. Otherwise they might as well be in a Corolla."
Reason: thought of 3rd upgrade
10-01-2010, 09:36 AM
#3
Durango Power Steering box- late 90's Durango with V-8 has a beefier box that bolts right in.
Bastard Pack Add-a-leaf budget lift- get some Dakota 4x4 rear springs or S-10 4x4 rear springs and add the main leaf as an AAL to your existing pack, gains 3-4" of lift.
Electric fan from a Taurus, gives more room for swaps and frees up about 10HP from your belt driven fan.
That is all I can think of at the moment...
10-01-2010, 09:48 AM
#4
E-fan out of a Taurus to get rid of the clutch fan stealing hp.
19lb ford fuel injectors
4.0 TB installed on 2.5L
8.8 rearend out of explorer
Bucket seats out of sunfire,cavalier,etc.
There are several junkyard upgrades for our YJ's. Look at what you want to upgrade then use the search feature to find write-ups on options.
10-01-2010, 12:41 PM
#5
Here's a few I've looked into and I'm planning on doing,
cs144 alternator from 90's caddy (for 90 and earlier yj), SI to CS adapter ( part # ECH EC82) is under $20 from NAPA, upgrade your charging cable to at least #6. (got this)
Heavy duty planetary from a Chevy/Dodge NP241, check to see if this will work for your case
Drive chain and gears from Dodge NP231D, its wider and stronger than the jeep's version
Front driveshaft from a Cherokee to shorten and use as a rear driveshaft once you get your SYE installed.
'95 and later Cherokee front axle shafts with the larger/stronger 297x u-joints, eliminates axle disconnect. (hunting for these now)
Junkyard line lock using a Subaru "hill-holder" brake valve, search forum for more specifics (got it)
York a/c compressor from a 80's volvo for onboard air. Some fitting required. (on my list)
I know there are more, just can't think of them now
10-01-2010, 01:00 PM
#6
high steer knuckles and bigger brake kit for the dana 30 off of a WJ
10-01-2010, 01:05 PM
#7
e350 master cylinder. locks up my 35s no problem 17.99 from autozone
[QUOTE=Hurley91;11462515]I could be drunk, high, raped and almost dead.... and I could still recognize it.[/QUOTE]
[url]http://www.jeepforum.com/forum/groups/ri-jeeps/[/url]
[COLOR="Black"][CENTER][SIZE="4"][FONT="Showcard Gothic"][COLOR="Black"][URL="http://groups.jeepforum.com/Built_Not_Bought"][COLOR="Black"]Built Not Bought #435[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
10-01-2010, 04:37 PM
#8
A side note on the Gas tank upgrade.
I was one of the lucky few who already had a 20 gallon plastic tank on my '88 Laredo, but it was cracked. A plastic tank from a '91 and newer YJ is an exact replacement. Something else to add. If anyone is upgrading to EFI, the electric fuel pump will drop right in without any modifications other than upgrading the fuel hoses to that of a high pressure type. Unfortunately though, I cannot tell you what year the electrical connector changed. On a carbed YJ, the electric fuel pump wire (orange) is already ran back to the tank, but it is not used.
If you're going auto, an AW4 out of any XJ before 1999 will work with little rewiring. (It would be helpful to have a wiring diagram grom the Great Lakes XJ website). In '99 they added a TCM to communicate with the ECM and the PCM.
"Some of the greatest inventions have come by extraordinary imaginations!"
Sign found at a wrecking yard;
"All parts have been road tested"
Project: Basket Case. 1988 YJ Wrangler(So much more to do)...
http://www.jeepforum.com/forum/f12/i...t-case-989208/
10-01-2010, 09:04 PM
#9
ISO 9001 Compliant
There is no limit to stuff you can find in a junkyard and make some use of. Springs, hinges, sun visors, lights, switches, relays all in addition to actual parts that fit like alternators and steering parts.
I carry a generic electric fuel pump I got out of some datsun pickup; it will get me off the trail if I need it.
Nissan pathfinder tire carrier.
Any number of cars have rear view mirrors with map lights in the bottom; just run some power to it.
York compressors for OBA.
Some ranger rovers have air suspension and air tanks.
Late model cadillacs have a huge bunch of big relays and 40-60 amp fuses under the hood.
You just have to walk thru the pick-n-pull with a creative eye.
Here's one that popped up the other day. A mobile shower for desert wheeling trips.
RV water pump, a little hose, some wire and a jerry can full of water.
Presto. Instant desert shower.
10-01-2010, 09:29 PM
#10
136 amp alternator off a Grand Cherokee, late 90's. Replace positive cable fitting with your old one and direct bolt in. Helps to upgrade grounds and battery cables.
10-01-2010, 10:14 PM
#11
I got both my D44's, taurus electric fan, surburban rearview mirror with compass/temp/map lights (with temp sensor and wiring, a couple sets of honda fog lights became under body rock lights and some other odds and ends in the junkyard. Luckily I haven't needed many jeep parts since I have owned my YJ since it was new and have been able to maintain it pretty well.
I do love going to the junkyard though.
2008 - Rubicon, 6 spd (stock for now)
1990 - YJ, 35's, 4.2, 5 spd, D44's, ARB's
10-01-2010, 10:29 PM
#12
Originally Posted by Sean H
.... surburban rearview mirror with compass/temp/map lights (with temp sensor and wiring, a couple sets of honda fog lights became under body rock lights and some other odds and ends in the junkyard. ....
I was wondering if those mirrors had a remote sensor, hmm.
Had the same idea for rock lights after seeing a grill-less honda at the 'yard.
10-01-2010, 11:06 PM
#13
Do you have any pics of this? How did you mount it?
10-02-2010, 06:20 AM
#14
Yeah, would love to see a picture too.
[B][FONT="Verdana"][SIZE="3"]Did you Hug your Jeep today?[/SIZE][/FONT][/B]
2008 Jeep Liberty
1994 Wrangler Sahara
10-02-2010, 07:54 AM
#15
ISO 9001 Compliant
