bubbling exhaust - JeepForum.com
post #1 of 10 Old 10-04-2009, 06:47 PM Thread Starter
johnroot01
bubbling exhaust
i just un-jerry rigged my exhaust today and welded it on the right way. even with it jerry rigged it had and still has a bubbling sound when i rev it. any opinions?
i'm trying to fix it, if i can, before i put on a new muffler.
95 YJ: 4" RC, 1" booms, 1" BL, 33x13.50x15 SS TSLs, 15" RCX steelies, minus sway and trac bars
ONLY IN A
|_Jeep_|
([ ]lllllll[ ])
johnroot01 is offline
post #2 of 10 Old 10-04-2009, 06:51 PM
GRN_BEAST95
is it happening when u rev it up or letiing it come down from the rev?
1995 YJ emerald green
4" RC lift & 2" BL
33x12.5x15 BFG AT's
Green Jeep member 153
Originally Posted by yellojeeper View Post
Guam. I spent a week there one night.
GRN_BEAST95 is offline
post #3 of 10 Old 10-04-2009, 06:52 PM
Louie4
You sure you fixed all the exhaust leaks? Is it straight piped?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #4 of 10 Old 10-04-2009, 08:00 PM Thread Starter
johnroot01
it comes straight down from the manifold, turns under the tranny, turns to the rear into the cat then the muffler.
i only have about 5-6 inches of pipe after the muffler.
it really only does it with the rpms on the way down.
ONLY IN A
|_Jeep_|
([ ]lllllll[ ])
post #5 of 10 Old 10-04-2009, 11:16 PM
87WhiteYJ
1987 YJ Wrangler
Back pressure, a new muffler should fix that. its the sound of exhaust savaging. Will quiet down after new muffler install. Also sometimes the back pressure will be increased with a air leak in the exhaust make sure your patched it up good so when the muffler is installed it goes away
87WhiteYJ is offline
post #6 of 10 Old 10-05-2009, 04:54 AM
vadslram
When I was a rodder I used to know I was ready when it bubbled on the let off, It meant that it was running rich enough to fire up in the exhaust. Not the way for daily but it ran better at WOT. Check your timing, it may need to be advanced.
vadslram is offline
post #7 of 10 Old 10-05-2009, 08:46 AM
93jeepyj
It may be the lack of a tailpipe causing that too, what kind of shape is the muffler in that makes you think it might be bad?
93jeepyj is offline
post #8 of 10 Old 10-05-2009, 09:53 AM Thread Starter
johnroot01
its pretty bad. the cat and the muffler need to be replaced IMHO. they are rusted like hell and feel kinda brittle.
ONLY IN A
|_Jeep_|
([ ]lllllll[ ])
post #9 of 10 Old 10-05-2009, 11:43 AM
vadslram
You describe it as Bubbling like it's getting reflecting pops.
Open headers will do that because with no backpressure you get unburnt gas sucked out of the cylinders.This can burn your exhaust valves if it goes on too long. A lot of backpressure is crippling but a little is needed.
If the sound is more like competing pops look for holes in the exhaust system the time between where pressure get to the hole(s) and out the end of the exhaust are different enough to sound kind on like bubbles. Plugged exhaust is easy to figure because you loose all power at higher RPM and it sounds more like a constant whoosh/whistle because there is so much constriction that the gasses come out like out of an air compressor.
vadslram is offline
post #10 of 10 Old 10-05-2009, 01:40 PM Thread Starter
johnroot01
thanks fellas
ONLY IN A
|_Jeep_|
([ ]lllllll[ ])
Paint Bubbling on Hinges AJ in Japan JK Wrangler Technical Forum 10 10-08-2009 07:31 PM
Door hinge bubbling Mr.Unlimited JK Wrangler Technical Forum 6 01-06-2009 06:13 AM
Bubbling steering fluid atakrator YJ Wrangler Technical Forum 7 04-01-2006 08:44 PM
Bubbling Paint Flyusaf2002 TJ Wrangler Technical Forum 3 12-22-2004 09:10 AM
Coolant bubbling??? Jeepfreak911 TJ Wrangler Technical Forum 4 09-06-2004 06:30 PM
