BTF Steering Bracket - JeepForum.com
post #1 of 2 Old 03-23-2010, 05:39 PM Thread Starter
notmyj
I am going SOA on the new YJ. I am using most of my parts from the old SUA YJ. I like the BTF steering bracket as it looks bretty beefy and I like the idea of the rod ends being in a double sheer mount.
I already have HD tierod and drag link with rod ends from BulletProofSteering.com and have used it on my DD for 3 years with out any issues or signs of wear. When I installed it, I had to drill the knuckles and pitman arm to 3/4" to accept the bolts in the new steering.
As I want to keep everything the same, I want to drill the BTF bracket to 3/4" as well. For those of you that have this bracket or have first hand knowledge of it, is there enough material to safely drill it to 3/4" without sacrificing the integrity of it? If I read right, BTF has it drilled to 5/8", so it would only need to go 1/8" larger.
Your thoughts?
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #2 of 2 Old 03-23-2010, 07:47 PM
timatoe
timatoe's Avatar
I don't have it but you could use 3/4 to 5/8 spacers at the rod end and run new 5/8 bolts. I doubt you'd have problems drilling it out, but you should contact BTF. I sent them a message when I had a question about that same set up and they got back to me the next day.
I ended up going with the JB4X4 bracket instead, just because I don't have the money to re-do the entire steering with new rod ends etc....
timatoe is offline
steering linkage bracket Rubikahn TJ Wrangler Technical Forum 14 04-25-2012 11:17 PM
Steering stabilizer bracket... ikiz TJ Wrangler Technical Forum 4 03-06-2009 04:09 PM
power steering bracket bigbelman2009 YJ Wrangler Technical Forum 3 02-11-2009 07:25 PM
Power Steering Bracket lovs2fly YJ Wrangler Technical Forum 3 10-03-2007 12:43 PM
Steering+Sway Bar Bracket=Help Metal TJ Wrangler Technical Forum 8 06-28-2006 12:29 PM
