Bronco 8.8 and dana 30? - JeepForum.com
post #1 of 3 Old 08-08-2011, 11:54 PM Thread Starter
RedneckJacob
1987 YJ Wrangler
I realize this is probably a terribly stupid question but i just want an answer.. Could you run a bronco 8.8 in the rear of an 87 yj (yes i realize it is full width and 4 inches longer than the d30 and. A 5x5.5 bolt pattern) but you can get eheel adapter kits for 40 bucks. So if i regeared my d30 to match the 8.8 could i run them? I have tj moabs so they have a good amount of backspacing. Would it look terribly goofy?
Or could i get the axle shqortened? Any idea on how much this costs?
RedneckJacob is offline
post #2 of 3 Old 08-09-2011, 12:05 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It would look like a Yj rat rod. Stick with the explorer for the 8.8. 9" on the other hand is worth narrowing down for a jeep because of the aftermarket support for them. They're also found in broncos, even some up to '87 but more common in the late 70's.
Luck Favours The Prepared
Anticanman is offline
post #3 of 3 Old 08-09-2011, 12:25 AM
NKYBRAD
Don't. You already knew that.
Brad aka formerly known as brads_nky_yj
1993 YJ - SOLD
2007 Toyota FJ Cruiser - In process
NKYBRAD is offline
Bronco Dana 44 on TJ? RimDJsTJ TJ Wrangler Technical Forum 8 04-06-2011 07:05 PM
Bronco dana 44 in a TJ? littledevilTJ TJ Wrangler Technical Forum 18 08-03-2010 05:38 PM
Shortening a 79 Bronco Dana 44 HP pmccoy9876 TJ Wrangler Technical Forum 2 02-07-2009 05:03 PM
79 Bronco dana 44 yj_hank YJ Wrangler Technical Forum 4 02-28-2008 06:04 PM
Hp Dana 44 71 bronco rontheman13 TJ Wrangler Technical Forum 1 04-20-2007 12:22 PM
