Broken zipper - JeepForum.com
post #1 of 6 Old 02-19-2012, 10:36 AM Thread Starter
7370MJD
Broken zipper
I was taking the top down for the first time this morning. I was trying to unzip the passenger side rear window. As I was pulling on the zipper, the handle broke off the zipper. I used some needle nose pliers to use the zipper, but any ideas for a fix besides taking it to an upholstery shop? Can you get a replacement zipper?
7370MJD is offline
post #2 of 6 Old 02-19-2012, 10:57 AM
crackedcornish
I just used a small black plastic zip tie looped through the part of the zipper that has the hole (where the handle was fastened on)...has an easier pull now that I have a larger loop to hold onto
crackedcornish is offline
post #3 of 6 Old 02-19-2012, 11:05 AM
ColoradoYJ95
So, let me get this straight.... you broke your zipper taking your top off for the first time?
ColoradoYJ95 is offline
post #4 of 6 Old 02-19-2012, 02:27 PM Thread Starter
7370MJD
yep broke my zipper......
I like the zip tie idea. I think that will work, thanks
7370MJD is offline
post #5 of 6 Old 02-19-2012, 02:31 PM
tdewit
Key rings
tdewit is offline
post #6 of 6 Old 02-20-2012, 10:58 PM
dilligaf69
Use paracord, you definately won't break that. I have it on all my zippers. The best part is you can tuck it up out of sight.
Dent, what dent.... That's not a dent.... that's a good memory.
dilligaf69 is offline
