Broken vacuum plug....should I be worried? - JeepForum.com
post #1 of 6 Old 06-03-2013, 06:45 PM Thread Starter
jason280
I pulled out my transfer case to day to do a SYE install, and found one of the four vacuum prongs is broken. Is this a fixable problem, or do I even need to be concerned?
jason280 is offline
post #2 of 6 Old 06-04-2013, 03:58 AM
90DesertTanYJ
Either replace it or lock your front axle over and change the switch to a Cherokee/TJ style to retain your 4wd light. Neither is hard and you will be done with 4wd engagement problems.
90DesertTanYJ is offline
post #3 of 6 Old 06-05-2013, 01:48 PM Thread Starter
jason280
It may be a non issue, as I believe my shift fork is locked over (front shaft spins in 2wd). Nevertheless, I did call Napa and Advanced to see if they had the part, and they wanted $119 & 99 respectively....found it on eBay for $19.99 shipped!
None
jason280 is offline
post #4 of 6 Old 06-05-2013, 05:59 PM
4.7stroker
I got mine from autozone or orillies for $15 or so.
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #5 of 6 Old 06-05-2013, 07:40 PM
90YJinPC
90YJinPC is offline
post #6 of 6 Old 06-05-2013, 09:23 PM Thread Starter
jason280
Hmmm, makes me wonder if the folks I spoke with over the phone were looking up a different part than what I needed...
jason280 is offline
