Broken thermostat housing bolt - HELP! - JeepForum.com
post #1 of 14 Old 08-24-2012, 01:19 PM Thread Starter
Rproject
1987 YJ Wrangler
While changing out the upper/lower hoses I decided the change the thermostat from 195 to 180. The nut on the bottom of the thermostat housing came off simple enough, but the head of the bolt through the center of the housing snapped off. While I'm none to pleased that it snapped, I would figure that the housing should slide right off the broken bolt, but it doesn't. Is the bolt threaded through the housing and into the engine or should the housing slide right off the broken bolt?
I've got the sealant loosened around the housing, but it appears to be stuck on the now broken bolt and there's no way to get a drill in there and an EZ-out to extract the broken bolt.
HELP!?!?!?!????
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #2 of 14 Old 08-24-2012, 02:04 PM
Louie4
"You pass butter"
Louie4's Avatar
I would wedge a paint scraper between the thermostat housing and cylinder head and go all around. Once that is done you can put a flathead screwdriver in and pry it off little by little all around. If the bolt head is broke on the upper bolt and there is no bolt in the bottom there is no reason it shouldn't come off with a little persuasion.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 14 Old 08-24-2012, 02:09 PM Thread Starter
Rproject
1987 YJ Wrangler
I got the housing off. Still have to determine if my gentle prying caused irreparable damage to the housing, but now I'm beating my head against a wall on this bolt. I've PB blasted the living daylights out of it and gotten a pair of vise grips on it to try to rock it back/forth to loosen it. She's stuck but good. Don't really want to go after heat since the v-belts are right in the area and I'm pretty sure I'll melt a belt or two.
Any other thoughts on how to get this bleeping bleep bleep bleepin bolt out?
1996 White ZJ
Rproject is offline
post #4 of 14 Old 08-24-2012, 02:37 PM Thread Starter
Rproject
1987 YJ Wrangler
I was trying to NOT call my buddy who's a mechanic to help me. I prefer the satisfaction of doing the job myself. After several text messages with my buddy and several applications of PB, I got a WIGGLE! I was ecstatic!!! 45 minutes later the bolt was in my hand and NOT in the engine compartment.
Time to go get a new stat, gasket, upper/lower hoses, bolt and maybe a housing.
1996 White ZJ
Rproject is offline
post #5 of 14 Old 08-24-2012, 03:17 PM
trboxman
1987 YJ Wrangler
Just a word to the wise...make sure you let the sealant cure for at least 20 minutes before you fill with antifreeze and crank over the engine...otherwise you're likely to get a nice little leak...
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
- Herbert Spencer
trboxman is offline
post #6 of 14 Old 08-24-2012, 03:37 PM
Cooter92YJ
Glad you got it out. If and/or when you get another broken bolt to deal with, try a good solid smack with a hammer, straight on if possible. Seems to help shock the rust/gunk loose in my experience anyway.
Cooter92YJ is offline
post #7 of 14 Old 08-24-2012, 04:33 PM Thread Starter
Rproject
1987 YJ Wrangler
Thanks Cooter, I did smack it with a hammer. Between that and the PB it finally came out.
trboxman, I put the stat in first, then went after the hoses. I'm hoping I didn't jack up the gasket putting the housing back on, but I don't think I did. Since the hoses were not exact replacements, I had to trim them a little. By the time I was done with that, I was well past 20 minutes, then I had to wait on my wife to come out and hold the funnel while I poured the recovered anti-freeze back in via a 5 gallon bucket, and we all know what wives mean when they say, "I'll be right there." LOL
1996 White ZJ
Rproject is offline
post #8 of 14 Old 08-24-2012, 04:37 PM
trboxman
1987 YJ Wrangler
LOL, sounds just like the last time I went through that process...
- Herbert Spencer
trboxman is offline
post #9 of 14 Old 08-24-2012, 06:38 PM Thread Starter
Rproject
1987 YJ Wrangler
Wee Hee no leaky. LOL
The whole purpose of this little adventure was to change to a 180 stat, which by the way has made an instant improvement in performance.
1996 White ZJ
Rproject is offline
post #10 of 14 Old 08-24-2012, 11:41 PM
timatoe
timatoe's Avatar
So why the 180* thermostat?
timatoe is offline
post #11 of 14 Old 08-24-2012, 11:56 PM Thread Starter
Rproject
1987 YJ Wrangler
Primarily to keep her cooler on the trail, but at her age, a little cool down is good for the soul (AKA block) :-)
1996 White ZJ
Rproject is offline
post #12 of 14 Old 08-26-2012, 12:04 AM
trboxman
1987 YJ Wrangler
FWIW, it was designed to run with a 195 thermostat...it's primitive computer is expecting that temp and will feed more fuel into the carb thinking that it's still trying to come up to temp.
- Herbert Spencer
trboxman is offline
post #13 of 14 Old 08-26-2012, 08:30 AM Thread Starter
Rproject
1987 YJ Wrangler
Thanks for the info. I'll keep an eye on my fuel economy to see if it drops at all, but so far she's running rather well with the lower temps. Quicker off the line and better acceleration from 40-55mph (she rarely gets on the highway).
1996 White ZJ
Rproject is offline
post #14 of 14 Old 08-30-2012, 05:18 PM Thread Starter
Rproject
1987 YJ Wrangler
Alright guys, it's been a week and here's the preliminary results of changing from a 195 to a 180 thermostat.
Fuel economy: While it's early, fuel economy has gone up 15%
Starting: No effect on starting, BUT, she definitely warms up faster and I can take her off high idle much sooner
Running: Quicker off the line, better acceleration from 40-55mph.
I have not seen a single downside to changing the t-stat from 195 to 180 and look forward to a cooler running engine on the trails.
1996 White ZJ
Rproject is offline
Bolt Size? .312-18x.238 or .970 (Thermostat Housing) cdrymalla TJ Wrangler Technical Forum 9 05-12-2015 04:32 PM
Thermostat Housing bolt heep1991 YJ Wrangler Technical Forum 8 01-22-2015 09:15 AM
Broken thermostat housing bolt cnt487 YJ Wrangler Technical Forum 3 08-29-2010 11:20 AM
Thermostat housing Bolt Bubba3200 TJ Wrangler Technical Forum 3 11-05-2009 09:55 PM
thermostat housing broken drtywtr YJ Wrangler Technical Forum 9 08-24-2009 10:07 AM
