broken steering box - JeepForum.com
post #1 of 5 Old 07-16-2013, 08:11 PM Thread Starter
1993bigblueyj
broken steering box
When at a stand still my box will only turn about 1/3 of its full range of motion to the right, but when moving it will turn all the way to the right and left. Seems like something is broken but can it be fixed? What is wrong with it? would it be easier to just upgrade to a Durango Box? I have 37's so i have wanted to upgrade and this might be the right time to do it.
1993bigblueyj is offline
post #2 of 5 Old 07-16-2013, 09:52 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Are the teeth of the pitman arm skipping on the sector shaft teeth?
Is the nut on the sector shaft tight?
Joe Dillard is offline
post #3 of 5 Old 07-17-2013, 05:53 AM
Rproject
1987 YJ Wrangler
Have you done anything recently that would have changed the indexing of the steering box? New lift, shackles, bod lift, etc?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #4 of 5 Old 07-17-2013, 08:56 AM Thread Starter
1993bigblueyj
No the teeth are not skipping and everything is tight. I haven't changed anything recently. It has been the way it is for 2-3 years with no problem. When you turn it to the right it will stop but you can force it over the rest of the way. It whines the rest of the way but it will go.
post #5 of 5 Old 07-17-2013, 10:47 AM Thread Starter
1993bigblueyj
Is the box just torn up or could it have anything to do with the pump?
