Broken rear shock mount - JeepForum.com
post #1 of 15 Old 03-26-2008, 06:10 PM Thread Starter
phylodog
My wife informed me that the Jeep was leaking somewhere near the rear end. I went out to take look and saw that I was losing a bit of lube from the rear diff. I then noticed that the left rear shock was hanging loose and the axle shock mount had broken in two.
I've ordered two new mounts (M.O.R.E.) and I'm hoping they'll arrive by Friday. I have a friend with a welding shop who has agreed to help me get them welded up but his shop is about 30 miles from my house. Couple questions:
Will it hurt anything to drive the Jeep over there? I'll try to take it easy of course but with winter just coming to a close the roads are a mess.
Would the shock mount breaking cause the rear diff to leak? It hasn't leaked before this and I didn't know if it may have torqued the axle a bit causing the leak.
TIA
phylodog is offline
post #2 of 15 Old 03-26-2008, 06:49 PM
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
i doubt it, a shockmount breaking off wont have the distance to hit the diff. i'd say it may just be coincidence that it is leaking. you may just have to replace the diff. cover seal, it'll give you a chance to replace the diff. fluid.
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>>
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline
post #3 of 15 Old 03-27-2008, 05:34 PM Thread Starter
phylodog
Thanks mean,
Does anyone have an opinion about driving with a broken rear shock mount?
phylodog is offline
post #4 of 15 Old 03-27-2008, 05:38 PM
ggjeep
No problem, just drive it! It just may bounce a bit more is all.
1996 XJ Sport 4.0/AW4
ggjeep is offline
post #5 of 15 Old 03-27-2008, 06:51 PM Thread Starter
phylodog
Good deal, thank you...
phylodog is offline
post #6 of 15 Old 03-27-2008, 07:49 PM
mean90yj
mean90yj's Avatar
be careful when driving it, a shock is used to dampen the springs because on a bump it will force your jeep up and cause it to almost want to lift that tire off of the ground slightly, a shock is obviously suppose to prevent that, drive it with caution but since you still have 3 shocks, its not very dangerous. i wouldn't recommend high speed driving though, like above 50.
~Enjoy>>>
mean90yj is offline
post #7 of 15 Old 03-27-2008, 08:03 PM
93jeepREDSOX
Yeah you will be fine, had a friend break a rear shock mount on his xj, took off the shock, wheeled the rest of the weekend and drove it the two and a half hours home.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
The build thread
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
post #8 of 15 Old 03-27-2008, 08:25 PM
schizm99
Yea take the shock off! Prolly throw it out it is probably beat to death. If you leave the shock on it can puncture a bunch of stuff! And thank your wife for noticing that somwthing is wrong!! Mine drives it till I notice!
89 YJ 4"rough country lift.
32-11.50-15 swampers
8000# black mountain winch
front lunch box lockers w/posi-lok
uniden cb, gt steering wheel, 4.10 gears
and anything else homemade
schizm99 is offline
post #9 of 15 Old 03-28-2008, 01:20 AM
timatoe
timatoe's Avatar
I drove mine for a couple of days before I saw it hanging there. I bet it looks like this....
I welded the two halves back together and then took a piece of 1/4" flat bar and welded it across the two as a reinforcement. I've got an 8.8 in the garage and couldn't justify spending any money on the D35.
timatoe is online now
post #10 of 15 Old 03-28-2008, 01:33 AM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
Broken shock mounts are really common. You didn't even notice it when you were driving did you?
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
post #11 of 15 Old 03-28-2008, 06:41 AM
jsahara24
you won't have any problem driving without the shock, but definitely get it fixed..
I did the same thing for my brothers jeep, it was my first welding project and it has held up for almost 6 months now, gave me a little bit of welding confidence...
99' Jeep Cherokee Sport
07' Toyota Matrix
jsahara24 is offline
post #12 of 15 Old 03-28-2008, 11:28 PM
mojo747
I noticed that my right rear lower shock mount was broken and the shock was gone. I've only had the jeep a month and was looking at the pinion angle when I saw it. I pushed down on that side and watched it bounce. Never noticed it while driving though. Go figure. Guess it is common. Having it welded up next week. Drives fine. I wouldn't worry about it. Remove that shock though.
Dave
mojo747 is offline
post #13 of 15 Old 03-29-2008, 07:39 AM Thread Starter
phylodog
I'll pull the shock this morning, thanks for recommending it. I wouldn't have thought of it and it makes sense to get it off of there.
phylodog is offline
post #14 of 15 Old 03-30-2008, 12:58 PM Thread Starter
phylodog
Well, I got the replacement mount welded on this morning and it's good to go! I couldn't help but notice that the shocks require very little effort to collapse them and I didn't notice any difference in the ride with versus without the shock on there. I'm thinking it may be time for a new set of shocks, anyone have any recommendations on which brands are good?
phylodog is offline
post #15 of 15 Old 03-30-2008, 01:06 PM
flame0086
I managed to break one of my rear shocks, not the mount, the shock. You might notice your ride to be a bit more bouncy. All the shock really does is dampen the spring (make it less bouncy).
100 mpg!! Western Washington Univeristy X-Prize Team
Support Search and Rescue
Get Lost
flame0086 is offline
Rear Upper Shock Mount Broken docdonnyb YJ Wrangler Technical Forum 4 03-27-2009 10:51 AM
Broken rear shock mount timatoe YJ Wrangler Technical Forum 14 08-04-2008 04:28 PM
Broken shock mount...again ZIMSJEEP YJ Wrangler Technical Forum 24 01-12-2007 07:19 PM
anyone ever have to repair a broken rear shock mount? scorpionkill YJ Wrangler Technical Forum 8 10-14-2005 05:40 AM
broken shock mount sadida31 YJ Wrangler Technical Forum 3 02-28-2004 05:29 PM
