Broken rear shock mount - JeepForum.com
post #1 of 15 Old 01-18-2008, 11:10 AM Thread Starter
timatoe
timatoe's Avatar
So, I was driving a couple of days ago, make a right turn hear a thud in the rear. I rolled down the window and didn't hear anything else. Thought, I must of hit a branch in the road or something since we've recently had a ton of trees go down. Anyhow, this morning I go to pull into the garage at work (graveyard shift) and I notice the left rear shock dangling on the Jeep.
It looks as though the mount has basically sheared in half.
I have an 8.8 sitting in the garage, and tried to explain to the wife that this is the perfect oppurtunity to get the rest of the parts I need to install that puppy and go SOA. I guess you know the answer I got, since I'm posting this.....
Any suggestions for fixing this??? I've got some 2" X 1/4" flat bar, I was thinking I could try butt welding the mount back together and then scabbing on a piece of the 1/4"... Anyone think this would work? I really just don't want to put anything into the D35, moneywise.
timatoe is offline
post #2 of 15 Old 01-18-2008, 12:07 PM
Michael_94YJ
I would probably just weld it back on. You could plate it if you wanted but if you get good penetration with the weld it should be fine.
Those shock mounts are kind of flimsy anyway. Weld it up and save $$ for the 8.8
1994 YJ 4.0L 5 spd.
flowmaster,15x12 wheels & 35x15 TSLs, sway bar discos, 3.5" leaves SOA + shackles, 2" body lift, JB steering bracket, SYE, M.O.R.E. anti-wrap bar, Bilsteins 5125s up front & BDS Hydros out back, axles in the works
Michael_94YJ is offline
post #3 of 15 Old 01-18-2008, 02:03 PM
cosminciortan
cosminciortan's Avatar
it's quite common. mine broke off just like that. I had it welded. it holds up fine for 1year now.
'95 2.5l red YJ. 35"BFG MTs on 4.5"SKYJACKER lift+ 5/8"Boomerangs, overhauled AX5 (still sucks)
smittybilt flares, bestop softtop and doors, double core aluminum radiator with Flexalite fan, new brakes allround, all poly bushings, armour
cosminciortan is offline
post #4 of 15 Old 01-18-2008, 10:19 PM Thread Starter
timatoe
timatoe's Avatar
Thanks fellas.
timatoe is offline
post #5 of 15 Old 01-19-2008, 06:04 AM
chuckyj95
Ya I brock the lower ones last year and the upper ones a week ago. there are alot of replacment lowers out there mine are M.O.R.E uppers you would have to do some creating
Chuck
Chuck Longwell
Mohawk NY
Looking for my next jeep
2008 Triumph Speedmaster
chuckyj95 is offline
post #6 of 15 Old 01-19-2008, 10:25 AM
RockWoRM
RockWoRM's Avatar
At least we know who wears the pants in the family.
That fix should work fine, until the 8.8 goes in.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #7 of 15 Old 01-19-2008, 02:32 PM
jaw41272
jaw41272's Avatar
I broke mine a while ago and due to a minor fuel leak , when I had it in the shop, I couldn't weld it for safety reasons, so I bolted some flat stock to it and it has worked as a temporary repair, on the road only of course. The other day I ordered a set of CJ lower spring plates, tech at 4wdhardware assured me they will fit, and that they were only approx 1" away from stock location, but when I look at where that stud would be, it viually looks like a smaller distance than that, anyway I ordered the plates for right and left, 15.00 each, waitng for them to come in and then I am gonna relocte my shock mounts.
91 Sahara 4.0l Operation Welcome Home Parade Veh #69
PARADE JEEP MEMBER #1Auto posi-lok equipped, 4" susp. lift
K&N Drop in and loaded with battle scars
FOR SALE 2005 PT CRUISER CONVERTIBLE
2005 Suzuki DRZ400S For SALE
jaw41272 is offline
post #8 of 15 Old 01-19-2008, 03:33 PM
richharr
I broke mine in the same place while driving to school, I welded it and put a plate on it to reinforce it. hasn't broke yet. On a side note, could you weld a new one to the axle without draining it?
93 4.0l 5 spd, 33s 4" lift
1. This forum requires that you wait 60 seconds between posts. Please try again in 1 seconds.
richharr is offline
post #9 of 15 Old 01-19-2008, 08:06 PM
Jesse-James
Jesse-James's Avatar
1989 XJ Cherokee
I moved mine to the front of the axle and got the M.O.R.E. upper mount relocators at the same time. Allows the same shock to be used for now and when the 8.8 goes in. The tabs for the axle side are very cheap.
Live in SE WI? ----->
Jesse-James is offline
post #10 of 15 Old 01-19-2008, 08:21 PM
OneLung
OneLung's Avatar
Be a man. Put your foot down and tell her that not only are you going to fix up the Jeep right, but that she's going to go out and get a second job to help you pay for it!
OneLung is offline
post #11 of 15 Old 01-20-2008, 07:55 AM
richharr
I couldn't find the smiley with a lawyer handing him divorce papers
richharr is offline
post #12 of 15 Old 01-20-2008, 08:20 AM Thread Starter
timatoe
timatoe's Avatar
OR more likely the one showing me with a big black eye
timatoe is offline
post #13 of 15 Old 01-20-2008, 08:50 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Courtesy of Dakuda.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #14 of 15 Old 01-20-2008, 06:32 PM Thread Starter
timatoe
timatoe's Avatar
Got it fixed this morning when I got off work, before it got too awful cold. Butt welded both sides and then ground down the back side and put a piece of 1/4" across it. I cut the 2" wide piece to sort of follow the lines of the mount. Should hold for awhile.
timatoe is offline
post #15 of 15 Old 08-04-2008, 05:28 PM
YJames90
YJames90's Avatar
Did the plates work. I have to do the same
My 2.5 to 4.3 swap thread
YJames90 is offline
Rear Upper Shock Mount Broken docdonnyb YJ Wrangler Technical Forum 4 03-27-2009 11:51 AM
Broken rear shock mount phylodog YJ Wrangler Technical Forum 14 03-30-2008 02:06 PM
Broken shock mount...again ZIMSJEEP YJ Wrangler Technical Forum 24 01-12-2007 08:19 PM
anyone ever have to repair a broken rear shock mount? scorpionkill YJ Wrangler Technical Forum 8 10-14-2005 06:40 AM
broken shock mount sadida31 YJ Wrangler Technical Forum 3 02-28-2004 06:29 PM
