Broken Pinion Shaft bolt! - JeepForum.com
post #1 of 8 Old 11-30-2005, 01:00 AM Thread Starter
skitch21
HELP! First off, i blew my spider gears up...opening up the case to check them out, i find the screw that holds the pinion mate shaft in is broken inside!! only about a half inch of threaded bolt came out. So now the shaft is stuck in there!!! what do i do? cut the bottom of the pinion shaft and try to expose the nut? is there another way to get the carrier out with out removing the pinion shaft?
thanks
skitch21 is offline
post #2 of 8 Old 11-30-2005, 05:14 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Your terminology is very confusing. There is no bolt holding in the pinion shaft. Do you mean the cross pin that holds in the spider gears? That does have a small screw/bolt securing it on a D35.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #3 of 8 Old 11-30-2005, 10:48 AM Thread Starter
skitch21
im sorry, wrote that post a little early in the AM
Yes that is what i mean, the cross shaft that holds the spider gears. the lock screw on that is stuck, broke off about 1/2 inch.
skitch21 is offline
post #4 of 8 Old 11-30-2005, 11:22 AM
jeepnguns
jeepnguns's Avatar
are you sure it was suposed to be a bolt I have seen both bolts and roll pins holding in the cross shaft.
sorry I just re-read you post and you said only part of the bolt came Out. about the only thing you can do is pull the carrier drill a small hole in the broken bolt using a drill press and then use an easy out.
88 Wrangler
350 Chevy engine vortec heads Holley Pro-Jection
Ford T-18 Tranny
Dana 44s Detroits w/ 5.89s
38" Swamper SX
Lots of other random things and dents
jeepnguns is offline
post #5 of 8 Old 12-01-2005, 06:54 PM Thread Starter
skitch21
I got it out! Thank god....6 hours later. drill and dremel. thank you. will post pics!
skitch21 is offline
post #6 of 8 Old 02-13-2011, 06:44 PM
LandRover
LandRover's Avatar
I've been waiting since 2005 and still no pics ... now dealing with the same situation and any ideas for removing that thing would be nice... anyone?
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Goodyear Duratrac 33's
LandRover is offline
post #7 of 8 Old 02-14-2011, 01:13 AM
lobukjeep
Actually they make a little convenient kit to take care of that pesky bolt.I had that happen to me on a dana 60 with c clip axles.so there was no way to pull the carrier to drill it.But you can throw together a make shift get up to get it out.Sears carries a 1/8" drill bit about 10 inches long.It allows your drill to clear the diff case so you can get a straight shot to the bolt.If you take a same thread size bolt and drill a hole through the center of it,you can use it as a guide to drill a hole in the stuck bolt.Then get a small extractor and twist it out.It's time consuming but you can get it pretty easy.Here's a visual.
http://broncograveyard.com/bronco/i-...actor-kit.html
"We don't call you son 'cause your bright"
lobukjeep is offline
post #8 of 8 Old 02-14-2011, 01:29 AM
TheUnknownOne
It is also wise to take a small ball peen hammer and hit the carrier where the cross shaft pin passes through it. The hammering will cause a shock through the metal. And when trying to twist the pin out, will allow it to pop free without breaking.
If you need to drill to get the pin out, it is best to drill slightly at an angle. you can then slip a small philips head screw driver into the hole you made, and use it as a lever to spin the pin out of the cross shaft.
TheUnknownOne is offline
broken pinion gear servozn TJ Wrangler Technical Forum 4 12-19-2009 08:47 PM
8.8 Pinion Shaft bolt stripped Danegerous TJ Wrangler Technical Forum 15 10-11-2009 09:21 AM
axle shaft touching pinion shaft kit05 TJ Wrangler Technical Forum 7 08-22-2009 12:42 PM
need help! broken bolt extractor broken. fltj TJ Wrangler Technical Forum 14 04-18-2008 01:32 PM
Differential pinion shaft Bolt? corison YJ Wrangler Technical Forum 2 03-13-2004 12:09 AM
