broken horn??? - JeepForum.com
post #1 of 9 Old 05-07-2002, 08:07 PM Thread Starter
bluYJ
broken horn???
The other day, I went over a bump (no big deal), and my horn started beeping non-stop. I pulled the connector to stop it (wouldn't you know, it was pouring down rain, so I didn't worry about it until the next day). When I hooked everything back the next day, the horn wouldn't work at all. I got another horn, but that didn't do anything. I checked the wiring in the engine compartment (for the horn of course). Anyone have any ideas before I take the steering column apart---ughhhhh.
95 yj, 4 cyl, auto trans, 4 1/2" Rubicon Express extreme duty lift,
33" BFG Muds, 4:88 gears, Detroit's front and rear, Dana 44 rear axle with disc brakes, heavy duty Dodge NP231,SYE, MORE sport cage. Blue Jeep Club Member #61
bluYJ is offline
post #2 of 9 Old 05-08-2002, 10:09 AM
Scorpionmk1
NO don't take the stearing colum apart.. check your FUSE, then Check the Re-lay.., if that does not work it's possible that the wiror lead that grounds out the circut that goes into your stearing wheel fell off.. in witch cans you can pop off the horn cover and reconect it..
Erik
94 Sahara on 33's
94 Sahara ..
33' BFG mud T's
Tomken,Sun,FXT,K&N..etc
86 CJ w/ Chev 35 Ford 9''(35-15.5-15) Super Swampers
79 Cj 33's 304 V
Scorpionmk1 is offline
post #3 of 9 Old 05-08-2002, 01:05 PM
JeeperJay
Its probably a combination of both the relay and the wire lead. My guess is the wire was grounding out on something for some reason and caused the relay to send power to the horn even when you disconnect the horn at the connecter. Over time the relay probably wore out, now the new horn isn't working. If it is the relay or a fuse, make sure you fix the wire lead or you may end up blowing it up again.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
post #4 of 9 Old 05-08-2002, 02:02 PM
RCHavok797
RCHavok797's Avatar
My horn only works when it wants to.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #5 of 9 Old 05-08-2002, 08:36 PM Thread Starter
bluYJ
OK, this may sound stupid, but where is the fuse and relay swith for the horn? It's not one of the fuses in the fuse box under the dash (that was the 1st thing I thought of, but after not finding any fuses or relays for the horn-thats when I started with the new horn and wiring).
bluYJ is offline
post #6 of 9 Old 05-09-2002, 08:41 AM
JeeperJay
I'm pretty sure the horn relay is in the relay box under the hood near the battery. If its still working you can ground the wire lead and you should be able to hear the relay click, just track down the clicking sound. If you have your owners manual, you can find it in there too.
post #7 of 9 Old 05-09-2002, 01:29 PM
evilpsych
evilpsych's Avatar
i dont use a horn anymore.. finger only
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #8 of 9 Old 05-09-2002, 06:41 PM
JeeperJay
I prefer a combination of horn and finger. Use the horn to get thier attention, then bust out the finger
post #9 of 9 Old 05-10-2002, 06:17 AM Thread Starter
bluYJ
OK, I seemd to have found what was stopping the horn from working again, it was a blown fuse in the fuse box next to the battery. NOW, I still have the problem that the horn won't turn off (needless to say, I pulled that fuse till I can find out this problem). I checked the outer horn ring on the steering wheel and it seems to be fine. The horn beeps even with that ring completely off. I've alreadt checked for any obvious loose wires. Any other suggestions (other than using fingers, etc...)lol?
bluYJ is offline
Horn wont work, relay and fuse ok and horn works if direct wired Redskin TJ Wrangler Technical Forum 5 01-02-2010 05:24 PM
Steering lock broken, now no horn? gettrdone YJ Wrangler Technical Forum 3 05-01-2009 05:58 PM
A Broken Horn TEEJAY TJ Wrangler Technical Forum 6 04-03-2008 06:31 PM
Broken horn Rubi22 TJ Wrangler Technical Forum 1 07-01-2007 04:15 PM
Broken Horn mrubin2004 TJ Wrangler Technical Forum 8 03-24-2004 12:32 AM
