Broken Heater Box Bolts - JeepForum.com
post #1 of 2 Old 02-08-2011, 10:22 PM Thread Starter
aldrichg9
While removing the heater box during my current rust repair project I managed to break 2 of the four bolts that hold it to the firewall.
The bolts seems to either be glued or welded to the inside of the heater box cover. Anyone have any experience removing and replacing these bolts without mangling everything?
I put some vice grips on the threads to try to break them loose by turning them but they are so soft I can't get anything to hang on and I am afraid if I get to rowdy with them I will just bend the cover and have leaks.
Thanks,
Greg
aldrichg9 is offline
post #2 of 2 Old 08-19-2011, 10:17 AM
88yjsyd
Hey that happened to me as well, I just did the heater core replacement yesterday. Only 2 of the 4 broke (the one behind the engine on the drivers side and the one to the far left on the passengers side), and the way they broke is the bolts still go through the fire wall just enough to hold it in. So, I lined it back up and just put on the 2 bolts that didnt break. It seems to hold fine, though the air conditioner is there to sort of holding it in as well. Should be fine, best of luck.
-Syd
88yjsyd is offline
bolts , box , broken , heater
4 broken bolts! AustinCJer TJ Wrangler Technical Forum 13 11-18-2009 12:44 PM
Broken Bolts bringbackphish YJ Wrangler Technical Forum 1 12-14-2008 10:32 PM
Broken bolts merdas TJ Wrangler Technical Forum 5 12-03-2006 01:00 AM
Broken Bolts!!!! Help!!!! beyondink TJ Wrangler Technical Forum 5 06-27-2006 07:56 AM
broken bolts need help RnEmOvr TJ Wrangler Technical Forum 4 07-10-2005 02:10 PM
