Broken harmonic balancer on shaft. Need advice can't remove. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Broken harmonic balancer on shaft. Need advice can't remove.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIron Rock Offroad products - get them from Kolak!TERAFLEX JKU 2.5" Elite LCG Long FlexArm Lift Kit w/
Unread 03-28-2015, 03:23 PM   #1
dvr6
93 2.5l....
Harmonic balancer self destructed when trying to pull with a harmonic puller. It's only moved about an 1/8" off.. Broken casting left only parts on the shaft that I can't grab with any kind of puller I know of. No lip at all to grab onto on the left side..
Any advice as to how to remove? If I drop the oil pan can I get to it from behind and tap it off the shaft that way?
dvr6 is offline   Reply With Quote Quick reply to this message
Unread 03-28-2015, 03:58 PM   #2
Jeepsr4me
i would cut the rest off. or take a slide hammer and hook behind it and hit it a few times if it breaks then good.. If it comes out good too..
then take the timing cover off and then you will be able to get a 3 jaw puller to grab the nub and pull it off..
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 03-28-2015, 04:17 PM   #3
pete1991YJ
pete1991YJ's Avatar
I would grind the rest of it down smooth and round, then pull the timing cover off the nub. For sure you will need a new seal there. Then drop the pan and use a 3-jaw puller or a slide hammer. You may be able to split the nub lengthwise with a sawzall to relieve some pressure, then it should just slide right off.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline   Reply With Quote Quick reply to this message
Unread 03-28-2015, 04:43 PM   #4
Chrisnvegas
Chrisnvegas's Avatar
That sucks big time.
I said some serious cuss words and I'll try to send you any e-good kharma I have built up.
What happens in my Jeep, stays in my Jeep
Chrisnvegas is online now   Reply With Quote Quick reply to this message
Unread 03-28-2015, 06:43 PM   #5
dvr6
Great advise thank you all. Looks like the e-good kharma may be working....
I cut off the excess and then ground it smooth. Was able to get the o.d. down enough so I could get the cover off. Tomorrow I'll try getting a puller behind it. The guard washer that sits between the sprocket and the balancer hub is in the way and the kit did not include a new one; so I don't want to cut that washer off if I don't have to...
Unread 03-29-2015, 08:51 AM   #6
Jeepsr4me
if you have a torch you can put some heat to that piece and it may just slide right off.
You local (ish to me)... If you need help..
If you have a drimel tool you could cut a groove in it at the key way and that will take the pressure off and it will slide off.
Unread 03-29-2015, 09:22 AM   #7
dvr6
I was able to get a clam shell gear puller behind it and it came off no problem. No damage to the shaft. Thanks again for the advise and the offer to come over to help.
Great group we have here.....
20150329_100618-small-.jpg   20150329_100918-small-.jpg   20150329_101005-small-.jpg
Unread 03-29-2015, 10:34 AM   #8
The_Goob
Hell on Wheels
The_Goob's Avatar
glad you got it. there is never a better time to replace that chain and such than now while its apart
The_Goob is offline   Reply With Quote Quick reply to this message
Unread 03-29-2015, 03:06 PM   #9
dvr6
Replaced all with new and Jeep is back on the road....
