Quantcast broken hard top. how can i fix it? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > broken hard top. how can i fix it?
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 03-04-2009, 07:45 PM   #1
dagoober
i left my hard top off my jeep this winter and the snow piled up and put a crack in the side. its more of a break than a crack because one part goes behind the other where it is broken. can i use jb weld on it or is there something better? also is it hard to get the side windows back in? the right side window poped out.
dagoober is offline   Reply With Quote
Old 03-04-2009, 07:57 PM   #2
oompaloompasc3
Fiberglass is a way you can fix it. The window I have no idea maybe some kind of glass shop could put it in for you.
1994 Jeep Wrangler SE 4.0 manual, AEM Brute Force Cold Air Intake, Red Optima, Banks Chip, Banks Header, Custom Downpipe, Flowmaster 50 Series, 35x12.50.15 BFG All Terrains, Black Steel Wheels with Simulated Beadlock, 3" Rancho Suspension, 3" BL, 3/4" brandon_yj Shackles, Line-X everywhere, So much more to do....
oompaloompasc3 is offline   Reply With Quote
Old 03-04-2009, 08:06 PM   #3
dagoober
ok thanks. i know a guy who works on fiberglass boats. im guessing its the same type of work for the roof.
Old 03-04-2009, 08:10 PM   #4
oompaloompasc3
yep exact same type of work.... good luck lets see some pics of the top...
Old 03-04-2009, 08:11 PM   #5
CheapSunglasses
2007 XK Commander
Just grind out some of the top about two inches on either side, and top and bottom of the crack, and refill with "Gorilla Hair" body filler....It's a body filler with fiberglass reinforcing hairs in it....It acts just like body filler, but stronger.
Sand, prep and paint.
"The Bannana Channell, Programming With Appeal"....Stay Tuned For a Bunch More!
CheapSunglasses is offline   Reply With Quote
Old 03-04-2009, 08:16 PM   #6
cadencedad
cracked top
a friend of mine had a tree fall on his.He fixed it then went to pick it up to put it back on and it cracked again.So make sure you be real careful with that area..
cadencedad is offline   Reply With Quote
Old 03-04-2009, 08:17 PM   #7
noodle9
side window install
go to your local auto parts store and buy the glass setting adhesive. It ia about $19.00 a tube. one will be enough. just follow the instructions on the tube. i did mine about 3 months ago and I put in the new trim around the glass. it is a pretty easy task.
noodle9 is offline   Reply With Quote
Old 03-04-2009, 08:38 PM   #8
dagoober
wow thanks for the amazing replys guys! i wasent expecting this many replys already! i 'll get the guy who does fiberglass to fix it properly because i dont want it to break again. i will get some glass setting adhesive tomorrow. i'll get a pic of it tomorrow because its a bit dark and cold out right now.
Old 03-04-2009, 08:58 PM   #9
kasbiker38
i dont think those windows use adhesive
kasbiker38 is offline   Reply With Quote
Old 03-04-2009, 09:42 PM   #10
dodger889
lost in the woods
dodger889's Avatar
Side window are set in a silicon adhesive just like the front wind shield are.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote
Old 03-05-2009, 05:36 AM   #11
lobukjeep
lobukjeep's Avatar
Not to crap on anybody's parade but that top is more than likely made out of SMC which is not fiberglass friendly.It really doesn't adhere very good.Has a tendency to seperate and fall off after time.You can use something like Norton Speedgrip.You can get different types to set up quick or slower.Stuff is hard as nails,can set up in 30 seconds and it doesn't itch.Only drag is it takes a special gun and tips to use it.But if you really had to you could buy a tube push it out in equal parts and mix it by hand and use it.Check it out.
http://images.google.com/imgres?imgurl=http://www.nortonautomotive.com/Media/Images/S0000000000000001044/SpeedGrip-Auto.jpg&imgrefurl=http://www.nortonautomotive.com/Data/Element/Node/Category/Category_edit.asp%3Fele_ch_id%3DC00000000000000017 95&usg=__s1oogIQrHMSjzBYuc4iXSTqwXTw=&h=280&w=309& sz=30&hl=en&start=7&um=1&tbnid=g2XrYe92Ro3A_M:&tbn h=106&tbnw=117&prev=/images%3Fq%3Dnorton%2Bspeedgrip%26hl%3Den%26safe%3 Doff%26sa%3DN%26um%3D1
"We don't call you son 'cause your bright"
lobukjeep is offline   Reply With Quote
Old 03-05-2009, 03:52 PM   #12
dagoober
looks like modified caulking gun lol. im not shure if it is fiberglass or something else. i'll get some good pictures wen i get home.
Old 03-05-2009, 09:11 PM   #13
MYYJ93
No real good way to fix it.
MYYJ93 is offline   Reply With Quote
Old 03-05-2009, 10:57 PM   #14
dagoober
i'll fix it for now. get a new one later uinless this one holds. need to find batterys for camera. have pics tomorrow.
Old 03-05-2009, 11:03 PM   #15
YJake
YJake's Avatar
I tried using fiber glass fiber and resin and the stuff just wouldn't stick to the hard top! It just kept slipping off like a wet noodle instead of bonding. I was trying to fix some chipped spots along the bottom edges.
I was forced to use a few layers of bondo to get the desired results. Maybe JB weld would work on your crack...?
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline   Reply With Quote
Glock Forum
