Broken Fuel Rail and Fuel Lines!!!! - JeepForum.com
post #1 of 13 Old 03-31-2008, 09:09 PM Thread Starter
narnold
I just found that my fuel rail was leaking from the quick disconnect fitting. I tried to take off the quick disconnect fitting and found that the fuel rail had rotted away and broke inside of the quick disconnect. I tried to get the fuel line out but...needless to say it doesn't want to. Now I am stuck with a busted fuel rail and a fuel line with my fuel rail nipple still inside...any ideas. There is enough of the fuel rail nipple left on the fuel rail to reconnect maybe a compression fitting but I really am not sure what to do. Short of buying a new fuel rail (which seems impossible to find) and a new fuel hose that leads to the other quick disconnect fitting on the frame (also impossible to find) what are my other options?? Any help would be greatly appreciated and thanks in advance...Oh yeah I pretty much destroyed the quick disconnect fitting in the process...
narnold is offline
post #2 of 13 Old 04-01-2008, 02:33 PM Thread Starter
narnold
Please somebody throw out some ideas I am really stuck here...
narnold is offline
post #3 of 13 Old 04-01-2008, 02:41 PM
djcondo
i would say replace the gas line and the fuel rail, if it is rotted away i think you need a new one. i would try ebay, summit, or just google it, and if all else fails go to a junk yard. also check daviesjeeps.com
- Dan
djcondo is offline
post #4 of 13 Old 04-01-2008, 03:05 PM
ggjeep
Check your PM box. I found a part.
1996 XJ Sport 4.0/AW4
ggjeep is offline
post #5 of 13 Old 04-01-2008, 05:18 PM
94YJEEPER
Pics? that might give me a better idea?
1994 Jeep Wrangler 2.5l.
2in lift
TJ wheels and 32in BFG AT's
Warn M8000 winch
94YJEEPER is offline
post #6 of 13 Old 04-01-2008, 06:32 PM
jws1961
There's a store on Ebay jeep rebuilders who I have bought used parts from. Try looking for them. Don't mess around trying to rig the fuel rail because its under pressure and the exhuast manifold is right under it. Not good. Good luck with your part search
jws1961 is offline
post #7 of 13 Old 04-01-2008, 07:25 PM
jeepin92yj
jeepin92yj's Avatar
go to http://www.findapartnow.com/ . it is only a site with his contact information but i just got my fuel rail last week from him, he said he has 7 in stock when i ordered. I would recommend ordering from him he had a fair price with excellent service and he ships out quick. and btw if you do talk to him say nick that ordered the fuel rail last week recommended him
-Black Betty-
4.0L 5spd
Rubicon 4" kit (5" of total lift)
5/8 Boomerang Shackles
2" body lift
35x12.50r15 Mickey Thompson MTZs
Ford 8.8 Rear with Rugged Ridge diff. cover
4.88s
Detroit locker in rear and Lock Right up front
jeepin92yj is offline
post #8 of 13 Old 04-02-2008, 07:16 AM
1 ton yj
1 ton yj's Avatar
Next time use the proper fuel rail tool to remove the fuel lines from the rail. Lisle makes them, the auto parts store will have them. They are not expensive. If you pick these up you may be able to remove the broken peice of fuel rail from your fuel line.
1 ton yj is offline
post #9 of 13 Old 04-02-2008, 08:49 AM
blake989
as for the quick disconnect fitting.....the only place I found it was at the stealer, I think I paid about $15 2 years ago just for the dang disco, which, IMHO is a cheap, thin plastic piece of ****. I feel your pain.
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security!
blake989 is offline
post #10 of 13 Old 04-02-2008, 11:03 AM
leedurr
leedurr's Avatar
1987 YJ Wrangler
I have a fuel rail if you still need one as long as it is for a 6 cyl
Lee
87 YJ, 4.5 RE lift with monotube RE shocks, 33 LTB's, 258 w/4.0 head, HEI, and Weber carb, Header, Comp 252H cam, Dynomax, cat back and much more.......
leedurr is offline
post #11 of 13 Old 04-07-2008, 08:23 AM Thread Starter
narnold
If anyone is looking for a fuel rail for a 91-95 2.5L I found this on ebay. I just ordered one, haven't received it yet but I will let all who care know when I get it to be sure it is right. Below is a link.
http://cgi.ebay.com/ebaymotors/JEEP-...spagenameZWD1V
narnold is offline
post #12 of 13 Old 08-27-2013, 02:28 PM
metalhead
2011 WK
My fuel rail is in rough shape also and I would like to replace it. I work at a jeep dealership and even for me its hard to get parts for a 94 wrangler. Most stuff is discontinued. I thought about making a rail if I could figure out how to do it.
metalhead is online now
post #13 of 13 Old 08-28-2013, 09:34 AM
Que89YJ
He will have anything you need at a great price:
Chris
810-650-3206
We buy sell and trade parts or full jeeps
Visit our website www.cfoffroad.com
Que89YJ is offline
Fuel lines that connect up top to the fuel rail bigredcherokee YJ Wrangler Technical Forum 3 09-02-2008 02:05 AM
Fuel Line Connector to fuel rail Slatega TJ Wrangler Technical Forum 2 08-31-2008 02:33 PM
Exhaust Manifold Help : Lost on how to remove Fuel injectors, wiring, and fuel rail. Mr. Notorious YJ Wrangler Technical Forum 9 08-10-2005 06:00 PM
Replaced fuel pump & no gas to fuel rail Part 2 BrianBC YJ Wrangler Technical Forum 0 08-24-2004 07:20 AM
Replaced fuel pump & no gas to fuel rail BrianBC YJ Wrangler Technical Forum 11 08-22-2004 10:41 PM
